Monostable multivibrator BJT
janraid_
Joined May 27, 2023
14
Hello, I'm a computer science student and I was assigned by my professor to make a monostable multivibrator circuit on a bread board with an unstable duration of three seconds. Keep in mind I have very little knowledge about circuitry, we were only given the schematic and were told to find the values for the components ourselves. After watching a YouTube video I got some of the values myself and ran the circuit on a simulator and the stable state worked fine, however when I applied a trigger pulse through the differentiator circuit the output (in this case tracked by a LED) turned on for less than a second then turned off. I can't determine the cause for this and as to why the light won't stay on for three seconds, I did the math for the time constant which is T = 0.693RC, at this point I'm thinking the differentiator circuit values are to blame.
sghioto
Joined Dec 31, 2017
8,724
Multivibrator circuit again?
I just did this in Homework! You guys must know each other.
Anyway the formula for the OFF time of Q2 is: T = RC
Your timing components are a 5uf cap and a 1K resistor, T = .005 seconds
Change the values shown in the edited schematic and run that through the simulator.
janraid_
Joined May 27, 2023
14
Alright so the light did turn off but the time interval is unknown since this simulator doesn't really show the time well, I'll try it on the breadboard today. Everything looks good thanks, however could you tell me why you chose 100nF and 1k for the differentiator circuit.
janraid_
Joined May 27, 2023
14
ps: what's the reason behind the light only turning on once and won't turn on again after that time until the circuit is reset.
sghioto
Joined Dec 31, 2017
8,724
Only need a brief pulse to turn ON Q1.
No need to load down the trigger input with a small 100 ohm resistor in fact a 10K works fine as well.
That's why it's called a monostable. It only has one stable state. When triggered it resumes that state after the delay time .has expired.
janraid_
Joined May 27, 2023
14
That makes sense. on the other hand, here's what I found out: 100k resistance is too much for the 2n2222 transistor I was using, it won't saturate (or so my professor said). I instead used a 10k resistor with a 300uF capacitor.
sghioto
Joined Dec 31, 2017
8,724
OK. You can also try other values for R and C to figure out the smallest value cap required.
I would start at setting R = 20K and C = 150uf, keeping the time constant the same until the value of R becomes too high to saturate Q2.
On my breadboard the circuit worked fine with a 100K and 33uf cap using 2N2222A transistors.
janraid_
Joined May 27, 2023
14
I did the circuit on the breadboard here's what I'm facing: the second I plug in the source battery, the light (output) turns on for 3 seconds (time interval) then turns off, it is not activated by the trigger pulse from the button. I'm using BC107 transistor could that be the problem? I'll try finding 2n2222 transistors
sghioto
Joined Dec 31, 2017
8,724
It's not the transistors or the LED would not have turn ON when first powered up.
Suspect the diode is in backwards or open. But as Cruts mentioned above you need to add a resistor.
Shown below is the 10K resistor needed.
janraid_
Joined May 27, 2023
14
After retouching it a bit I got it to work and here's what I got, to be honest I'm quite happy with the result. I assume the initial light is the capacitor discharging and the second one is in response to my trigger. I did add that 10k resistor to the switch and I didn't notice much difference with or without.
https://streamable.com/ms21g8
sghioto
Joined Dec 31, 2017
8,724
I don't see the 100nf cap on the board.
EDIT: I see the cap now but if it's installed correctly it will only trigger the circuit one time.
