Hi MikeML,I looked up the installation manual on some similar sensors (since Lewis hasn't provided the model number that he intends to use). The "end of line" resistor that he talks about is actually connected in parallel with all the sensors. I think it is a method of making sure that the bus has not gone open...
Here is my best guess as to what is going on showing both the EOL resistor R1 and a sensing resistor R2
The 24V supply is actually inside the Alarm Panel. It likely is wired in series with a sensing resistor R2 (as I surmised way back in my first post), which serves both to limit the current from the power supply, as well as to provide a voltage proportional to the total current being drawn by the sum of the EOL resistor and the sensors.
To protect the A/D input, I have added a series resistor R3 and a 4.7V Zener diode, which will allow measuring the difference between the just the EOL resistor with no alarms, and the first and subsequent alarms. If multiple sensors alarm, the Zener limits the voltage into the A/D.
Now we just need to agree on R1 and R2...
In post #5 I posted the datasheet of the sensor (page 7), even know these alarm panels are designed to work with all kind of conventional smoke sensors like these.
The schematic you posted looks great. I like the idea of sensing on the negative wire, but how would this be done as the voltage will always be 0V ??
Another thing, what protection would this circuit have against short circuits?
