Ask help from an experienced person on LED monitor
abdulbadii
Joined Aug 30, 2017
91
Any experienced person on LED monitor help me out please.
Dell 2020H (or sort of it) LED backlit LCD monitor is having many small, thin white stripe in quick sparkle, gleam or blink appears on LED monitor when and because of its AC plug connector/head cannot be firmed, get contacted
Meant, need any expert who really has experienced, gone through fixing this imperfect connection to be otherwise so, in such that his reply should be a convincing working fix, because the will-be-repaired object is really in middle of use; a monitor that is being used displaying this post and other electronic forum pages else, and the only one visual output tool available here right now
Please help as this condition actually has been right after the object received from delivery and was set up, started right away
but feel very reluctant toward hassle claiming the correct good replacement
Thanks much sincerely
Benjamin3000
Joined Mar 28, 2021
31
Are you talking about the "inlet" to the monitor where the cord goes in?
That's usually not a difficult thing to replace, if the monitor can be re-sealed after taking it apart (sometimes there's screws, other times there are snaps, like in a car, then there's monitors using both)
You will probably have to take it apart first and get an idea of whether it's panel mount with screw terminals, panel mount with free hanging wires (the wires inside the monitor, would be permanently attached to the inlet connector itself, and then either have a plug to the board or just be soldered into it) or, it may have through-hole solder pins that go directly into the board (hopefully using the rear panel to support it)
This sounds like a classic loose AC connector contact issue rather than a monitor hardware fault — the flickering/sparkle pattern you're describing is consistent with intermittent power interruption caused by poor contact at the plug.
A few things to check/try before assuming you need a replacement monitor:
  1. Try a different AC power cable/cord if you have a spare one with the same connector type (IEC C13/C14 is standard on most monitors) — cables wear out at the connector points over time.
  2. Inspect the plug's prongs and the monitor's inlet socket for any bent pins, corrosion, or looseness — sometimes gently bending the prongs slightly (carefully, unplugged) restores firm contact.
  3. Try a different wall outlet entirely, in case the issue is actually on the outlet side rather than the monitor's connector.
  4. If the monitor's internal power inlet itself is loose (not just the cable), that would need a repair technician, but a simple cable swap is worth ruling out first since it's the cheapest fix.
If it helps to understand the plug/connector standards involved (useful before buying a replacement cable), this breaks down the different electrical plug connector types and their standards well.
