Modulo-2 count up and down. [Solved]
Cstp
Joined Feb 19, 2019
9
Hi everyone, I tried to design a modulo-2 to get this sequence 00,01,10,11,01,10,00. But glitch append at the ouput of the XNOR (cd4027) and trig the flipflop
randomly. So do you have any suggestions to design this circuit?
BobTPH
Joined Jun 5, 2013
11,620
A modulo 2 counter would have only 1 bit and there is no difference between counting up and counting down. In other words, a modulo-2 up / down counter is nothing more than a T flip-flop.
Did you perhaps, mean 2's complement rather than modulo-2?
Bob
Zeeus
Joined Apr 17, 2019
616
Use 3 JK flip flops but with 2 outputs Q1 and Q0
J2 = Q0 * Q1 logic and
K2 = Q1
J1 = Q0
K1 = Q2 + Q0
J0 = Q0' (Q0 inverse)
k0 = Q1' (Q1 inverse)
Produced your counting sequence.
dl324
Joined Mar 30, 2015
18,449
This is in the homework section. We don't do the homework; we offer guidance. Students will learn more that way and can't be accused of cheating.
EDIT: My apologies. It sounded like homework to me and I thought this was in homework help.
Deleted member 115935
Joined Dec 31, 1969
0
Counters with a decode, will generally give a glitch out as all the bits of the counter will not switch at exactly the same point / speed.
Well done you for detecting and diagnosing the glitch ,
So the answer, is to either remove the glitch, or ignore the glitch ,
You have been shown a way of removing the glitch , a low pass filter
what do you think could be the problems with a low pass filter, think about the frequency spectrum of an edge.
An alternative method,
what time is the glitch in relation to the clock,
think of the timing diagram, is it after or before the clock ?
is it the glitch there for more than one clock ?
Cstp
Joined Feb 19, 2019
9
It's not for homework but I should have stayed in school longer lol
Cstp
Joined Feb 19, 2019
9
K2 = Q1
J1 = Q0
K1 = Q2 + Q0
Thank you very much, I really appreciate it. I will try this circuit soon. But I managed to get my circuit to work. I think my breadborad was causing me the problem.
Cstp
Joined Feb 19, 2019
9
Cstp
Joined Feb 19, 2019
9
Bob
Yes I make a mistake But you guys correct me and I appreciated. After that I understood that I want to make a modulo 6.
Cstp
Joined Feb 19, 2019
9
Hi C,
Welcome to AAC,
What is the clock rate from the 555 timer,?
Have you tried a short R/C filter on the 4027 output.?
E
Yes I try with filter but I managed to get my circuit to work. I think my breadborad was causing me the problem.
Cstp
Joined Feb 19, 2019
9
Thank you that confirm what I think. Thank you I will consider all your advice soon in my next development
MisterBill2
Joined Jan 23, 2018
28,070
What the description of the desired output requires is a two-bit binary counter. That can be realized with a single dual flipflop IC such as a CD4013. which is a dual R-S with Trigger input positive logic IC. The source of pulses would be separate, and a 555 timer IC can provide that
