Cyber Game Discount <= Cyber Game Over
Benjamin3000
Joined Mar 28, 2021
31
Preface: Off topic because it's not asking for electronics advice per say, it's a satire / parody of bad engineering that I figured many electronics techs could relate to, whether they were in the arcade industry or not. It might be a bit boring to non-techs, but that's why it's still in the "all about circuits" forum and not a general writing forum, albeit under the "off topic" thing.
Many years ago, there had been a discount electronics company that tried to get into the arcade game market. They opened up a new branch of their company, and named it “Cyber Game Discount”
Although they came up with a few original game ideas, the majority of them were clones of famous successful ones, deviating from the original artwork and names enough to avoid having to pay copyright / license fees.
For example, there was a Galaga clone called “Tractor Beam Aliens” which, as the name implied, had a similar double shot powerup mechanic to Galaga, among other similarities. Ironically, they also had background music during the game, which Galaga itself didn’t.
Then there was Race Car Roundup, where you actually weren’t in a “race” per say, other than your car just went really fast. You had to avoid the red cars while picking up all the flags. There weren’t as many flags as there were dots in Pac Man, but you were going through a maze and couldn’t jump over enemies, thus the game play strategy was similar to Pac Man.
At first, players enjoyed these games, and some places ended up having arcade games that couldn’t afford or justify the cost of the more famous ones. Even people who wanted their own arcade machines in their homes but couldn’t afford a Galaga machine, ended up settling for Tractor Beam Aliens instead.
Unfortunately, the saying “you get what you pay for” rang true, very quickly.
Within just a few weeks of getting the new games, arcade owners and technicians were already needing to do repairs on them, when others would usually run for a few months to a year without any major failures. Unfortunately, Cyber Game Discount put little thought into the needs of technicians and how they would be able to adjust or test things. They also cheaped out on many different component choices, opting for electrical components that were just barely strong enough to withstand their normal load, effectively shortening their lifespan. But that was only the beginning.
Harry had a problem with his Tractor Beam Aliens game. The screen was blank one day when he powered it up to open the arcade. Knowing that just the monitor could fail and allow the motherboard to continue working, he opened up the coin door and tried the coin sensors, then the start button. No sound. At this point he noticed the lights on the game were out as well, which indicated that the main fuse was probably blown. He was right about the main fuse, but that was the least of his problems.
Thinking ahead, he measured resistance to ground on each power supply output to see where the short was. It was on the 5V line, but in order to disconnect the power supply from the motherboard, he had to cut the wires because Cyber Game Discount didn’t bother putting connectors between boards. He opted to cut them instead of desoldering them at the board end, so that he could match color codes and ensure he did it exactly right.
After clipping the 5V lead, he discovered that the short was on the motherboard somewhere, not in the power supply. He figured this would take a long time to find on his own, so he just made an “out of order” sign to put on the game that day, and then made a note to himself where the short was. At this point he noticed that the game had only a main fuse. There were no separate fuses for the 5V and 12V lines, nor for the monitor. He made another note to figure out the proper current draw on the 5V and 12V lines and add his own fuses, anticipating further problems otherwise.
He found that there was a screw on the motherboard that had come from somewhere above, probably the monitor, and it fell there and caused a short circuit. He was perplexed that the game was already losing screws this early in it’s life when he was the only one who had worked on it yet, but he naturally just assumed it was that the game got struck by aggressive players one too many times.
He examined the power supply and found that a large transistor that was used to regulate the 5V line had burned up. Unfortunately, it had gotten so hot that the board surrounding it had blackened, and when he unsoldered the burned remains, the traces came with it.
He was no stranger to lifted trace repair, but such damage was usually the result of previous botched repair attempts, or someone bypassing the fuses, not poor design. He tried to write to Cyber Game Discount to get a warranty replacement, but this request fell on deaf ears, and Harry chalked it up as them just assuming he caused the traces to peel off somehow.
As much as he wanted Cyber Game Discount to replace the power supply board for him, he decided to cut his losses and repair the traces, replace the transistor, and then add a fuse to the 5V and 12V lines after getting their average current value. He also made a mental note to ask other arcade owners about whether a game company includes separate fuses before buying any games from a company he hadn’t heard of before.
Without knowing exactly what the motherboard drew normally, he took an educated guess based on other games he’d dealt with of similar graphical capacity, so to speak. He assumed a 1 amp fuse should do the trick, and if it blew, he’d just use a multimeter to figure out the actual current draw of the motherboard. Instead of just splicing the power supply wires back the way they were, he added a fuse inline with the 5V positive and the 12V positive wires, leaving the ground wires undisturbed as they should be.
He had the voltage meter attached to the motherboard’s power input and, after replacing the main fuse to the machine, plugged it in and pulled the power switch on the top. The meter showed 5V for a moment, then 0V. So, perhaps there was a problem with the main board, or he guessed wrong about the fuse value. However, in a couple seconds, he heard several loud pops and hisses from the power supply, and also the monitor made a couple similar sounds as well. He clicked off the main power switch but the damage was already done.
Several capacitors on the power supply had popped and released their magic smoke, and several more were bulging. The machine reeked of burnt out capacitors and transistors, a smell that sends shivers down many technicians spines, knowing that it usually means something very bad, and expensive, has happened.
He looked at the fuse that he had added for the motherboard, wondering why it didn’t break before the power supply burned itself, only to find that the fuse was, in fact, broken. But he could have sworn he saw 5V come out of the power supply for a moment before the fuse broke. How could it have been stable and then blown that many parts after repairing it? He figured a mistake would have either resulted in no output or excessive output.
At this point he realized he should have tested his repair into no load, or into a dummy load, before hooking up the motherboard. He was just too angry about the lack of current protection to take that additional precaution. Sometimes, a power supply does need a load to regulate, however, so a no-load test could be misleading if you see the 5V line read something like 5.6 to 6 volts.
He figured he would just bite the bullet and order a new power supply instead of trying to salvage the one that blew multiple capacitors and who knows what else after his repair attempt. He thought about a different one, but the Cyber Game Discount power supply was cheaper than any other reputable brand that he could find with both a 5V and a 12V output, not to mention the mounting holes and HV inlet plug would match.
He held on to the broken power supply to see if another tech could show him what he did wrong, and take notes for future reference before he threw it away.
Once he got the new power supply, he decided he’d start his better practice of verifying voltages before connecting the expensive boards to the supply, since he needed to figure out the motherboard’s current draw anyway to “fuse” it properly.
So, with the machine still unplugged, he plugged in just the HV input connector inside the machine and mounted the supply, figuring he’d check no-load voltage first and then try a car light bulb he had handy as a load, if the no-load voltage was higher than normal. That way he’d know what no-load voltage was “normal” for future reference and to train any new techs.
With the meter attached to the 5V output, he plugged in the machine then pulled the power switch again. The meter went up to 9V, which seemed a bit high even for no-load voltage, but before he could try his test bulb, the power supply began hissing and loudly popping, with capacitor fluff flying every which way and several entire capacitors flying off the board. He didn’t even have time to cut the power before the main fuse had blown, but he also noticed that there was smoke coming from the monitor as well.
He looked closer at the monitor board, and found that the HOT was visibly burned up. Now he was frustrated beyond belief. The low voltage power supply had nothing to do with the monitor board whatsoever, other than powering the motherboard that gives it a signal. Even an overvoltage to the motherboard shouldn’t be able to damage a monitor. He had seen VCRs have liquids spilled on them, and terribly botched repairs that made things worse, but he never saw a VCR somehow damage a TV, nor an arcade motherboard damage a monitor. The game was months old, far too young to have multiple unrelated parts just popping left and right.
He called Cyber Game Discount’s customer service line, and asked about a warranty claim for the monitor’s circuit board, along with the new power supply that just was apparently a DUD (defective upon delivery).
As soon as he mentioned the power supply, the customer service representative asked him “Did the monitor have power to it without a signal?” to which Harry replied “Yes, because I turned on the switch to the whole machine to give power to the low voltage supply and test it, but I didn’t have the motherboard connected to power” and then the tech replied “Well, that’s probably it right there. If you give the monitor power without a signal from the motherboard, it often breaks. Unfortunately since you did this in the field during a repair attempt, I can’t count this as a warranty repair.” “What kind of design is that? Like what if the motherboard just freezes up on it’s own? Or we want to check if the monitor works before we order a new motherboard? I mean, nobody replaces the motherboard and the monitor all in the same day, they just would buy a new game” “Sir, I can’t do anything about this.” “Well, it’s not like you designed it, though” (click)
Harry was now really wanting to put his fist through the monitor, or roll the game out back and destroy it with a chain saw or a blow torch. He had never seen a monitor that could be damaged by the absence of a signal before.
Harry asked another arcade tech, Owen, to examine the power supply board and see if he could figure out if Harry had done something wrong to cause it to blow more parts after his initial repair. Owen said “Okay, so I recommend first of all, just get a Mean Well power supply, or a Triad Magnetics power supply, or maybe I can show you how to rig up a PC power supply to run the game. Because the Cyber Game Discount power supplies are a pile of $#17. Did you try it without a load on it, by any chance?” “Why does that matter?” “The Cyber Game Discount power supply needs a load to regulate the voltage, which isn’t unusual. However, the capacitors are 6.3 volts maximum, or they’ll blow, and if you turn on the power supply with nothing connected, the voltage will rise up to like 9 or 12 volts, and boom.” “You’ve got to be $#177ing me.” “Well, that’s why I usually put a different power supply in these things”
Harry said “Also, did you know the monitor will burn up if you give it power with no signal?” Owen looked surprised and said “I’ve been trying over and over again to fix this Cyber Game Discount monitor on the bench without a game board, but it keeps frying itself! I was going to give it a signal after I confirmed that the monitor powered up on it’s own, but that was my undoing!”
Harry had dealt with games that became money pits after a few years, but the Cyber Game Discount Tractor Beam Aliens machine was the quickest Harry had ever seen an arcade machine go from “money maker” to “money pit”. The only time he ever had damaged something further during a repair attempt was well before he had an arcade of his own. He had never seen a monitor burn up with no signal, nor a power supply burn up with no load AND lack overcurrent protection all in one machine. But Tractor Beam Aliens almost felt like an engineering teacher wanted to build an intentional example of how not to design a product.
A few weeks later, Harry had fixed the monitor and rigged up a different power supply to power the motherboard. Tractor Beam Aliens sprang to life, but within the same day, the joystick became loose and didn’t respond properly. Harry figured that the screws had come out, but it wasn’t just that, but the screw holes in the control panel were stripped out, so he had to jury rig a way to mount the joystick.
The next day, one of the switches in the joystick assembly failed, and all the creative jury-rigging to mount the stick with the stripped screw holes had to be undone. Harry called Owen and asked him how he should fix this problem. Owen jokingly suggested giving the machine 240 volts outdoors and watching it go up in flames and buy Galaga to replace it, but then suggested that the control panel was a standard shape and size so that several other joystick games with one button would work. All that had to be done, aesthetically, was to replace the artwork or just stick a neutral design there.
Harry had already sworn off buying a Cyber Game Discount machine ever again, but during a contest, he got a voucher for a free Race Car Roundup machine. He of course accepted it, figuring that he’d sell the working parts when it inevitably failed.
People were enjoying Race Car Roundup and the other games that Harry had in his arcade, until one day, he began to smell burning electricity, somewhere in the building. He was obviously alarmed, but had seen enough cartoons and comedy sketches to know better than to just yell “fire”. After all, the alarms hadn’t sounded yet and no actual smoke was visible, and there was still power to the entire building.
He looked around and around, trying to find a game that either lacked power or the lights or screen was flickering badly. He couldn’t find anything. Every screen that was lit was the proper color and stable, and the only blank screens belonged to games that were already unplugged.
He walked around the building and looked for flickering lights, looked behind the games for frayed cords or a damaged outlet, and looked in the closet where the electrical panel was. The smell was definitely coming from somewhere in the actual gaming area itself, not the closet or bathrooms.
He looked around for anyone who might have been smoking a cigarette, in case he mistook that for electrical smoke somehow, but couldn’t find any visible smoke or any evidence of a recent violation of the “no smoking” signs.
Harry asked an attendant to follow him into the closet and asked discreetly if he smelled the electrical burning smell on the gaming floor, and the attendant confirmed that he could smell it, too, but couldn’t see any signs of major electrical failure.
Harry decided that instead of pulling the fire alarm, he would pull the main breaker to the arcade instead so it would just look like a power outage. Harry radioed to all the attendants that if anyone complains of their game being interrupted, to just give refunds for the amount of that game they were playing, no questions asked, and then he shut off the main breaker.
While the attendants were apologizing for the “power outage” and ushering people out, Harry had to find an electrician that did “emergency” calls, i.e. a business disruption or a safety related electrical fault.
Once the electrician, Percy, showed up, he had Harry lead him to the electrical box. Percy put a few safety cones around the panel and then unscrewed the outer cover. He measured the input voltage going to the main breaker, then turned off everything except the refrigerators for the snack bar, figuring Harry would want those re-powered first if it was safe to do so. The voltage was stable upon powering the refrigerators, and Percy examined those cords and found them to be in good condition. The fridges were drawing normal power. He repeated this for the building’s HVAC, and thus they had ruled out any of the “critical” loads (since food would spoil if the fridge had no power for too long) and then let just those and the HVAC run for a while.
They opened all the doors with the HVAC running just the fan to get rid of any residual electrical smell, so that they could re-energize things one breaker at a time and figure out where the fault was. They were going around with extinguishers at the ready, in case the faulty fixture erupted in flames. Harry had given Percy one of the walkie talkies and was carrying one himself, so he could order an immediate shutdown if needed.
Percy checked the lights, and asked if anything had recently been mounted to the walls, in case a screw or nail had penetrated a hidden cable by mistake. Harry and the attendants all said “no” so Percy said the lights were okay to turn back on.
After turning on a few more miscellaneous things, the only things left were the outlets running the actual arcade machines. They figured they could do one set of outlets at a time (usually there were 4 of them to a breaker) and look inside all the games on just that circuit – not an hours-long teardown, but just an exploratory check to figure out where the smell was coming from, and while they were doing this one game at a time, whichever one it was would have time to reveal itself. They could also check for any botched “repairs” if Harry was unaware of someone’s mistake that caused this problem.
Some time later, they figured out that Race Car Roundup was causing the smell. Harry was perplexed that the screen and the music were perfectly fine while the machine was slowly roasting itself inside. He figured out the power supply was faulty because it smelled bad even with the power turned off, so he managed to get a warranty replacement from Cyber Game Discount.
Owen and Harry were looking through a catalog of newer arcade games, and saw some of Cyber Game Discount’s other offerings. There was a version of Tractor Beam Aliens that had 2 joysticks and 6 buttons per joystick. However, two people couldn’t actually play at the same time, despite the outward appearance. It was for redundancy so that when one joystick failed, the other could still be used, and any of the fire buttons did the same thing, so they would all have to fail to stop the game from working.
Owen told Harry about how he had seen so many “Major Military Mission” games with motherboards that burned themselves, that he and several other arcade owners nicknamed them “Major Malfunction” or “Major Engineering Failure” even as far as some players having grafitti’d the marquee, and the owners didn’t even bother to replace the marquee, because it was just too accurate and funny.
Owen then went on to point out how silly and over-engineered their “solution” to the control panel failures were. He said that having redundant buttons makes sense for a safety critical application where you need to shut something down immediately and the emergency cutoff button had to work the first time, or else. For something like a video game, using a long-lasting button makes more sense than confusing people with extra buttons that imply additional functions that aren’t there. Harry then went on to say “Yeah, the way their buttons are made, you might have that in your arcade for a week before all the buttons break anyway”
A few weeks later, the ominous smell of electrical burning returned. Harry started looking around the arcade again, seeing no signs of failure at first. However, while he was investigating the source of the smell, he heard a few pops and then someone yelled “OH MY GOD! THAT GAME’S ON FIRE!” and then the fire alarm began to ring. Harry shouted “Please walk to the nearest exit, don’t panic, and don’t push each other, you’ll be fine!” and he saw the source of the smoke. It was Race Car Roundup, which had smoke coming out of the top – while the screen was still lit and flashing colors incoherently like a disco. Harry headed for the breaker box and cut power to all the “game” circuits, not remembering which one Race Car Roundup was on. He then looked for any remaining customers to ensure everyone made it out okay.
The fire department rolled up and Harry explained that Race Car Roundup had gone up in smoke and must have tripped a detector on the ceiling. They opened it up and saw that the power supply for the motherboard had clearly been the source of the billowing smoke.
It was later discovered that when Cyber Game Discount did the safety tests, where power supply outputs are shorted to ensure that such a fault could not cause a fire, they passed the safety test – but only because no actual flames were visible. The flawed power supplies not only would be permanently damaged if the output was shorted, but they also created large clouds of smoke, enough to trip a smoke detector. There had also been several arcades where the fire alarm had been pulled after someone saw that much smoke coming from a game and thus believed it to be on fire.
These sorts of incidents were the final death blow to Cyber Game Discount. Arcade owners shunned the machines and the company alike, nicknaming them “Cyber Game Over” as sales basically fell off a cliff. Several people made jokes about the engineers holding the lead solder in their mouth while building the machines, or that the engineers were smoking more than just the power supplies.
Race Car Roundup, being an original idea of theirs, ironically got copied as Rally-X, a much more reliable version of the same game.
The players joined in on the “Cyber Game Over” moniker, as they began rapidly disappearing from arcades after spending more time “out of order” than actually being playable. Owners either dumped them out of frustration or due to fear of an electrical fire. It even got to the point where arcades started advertising the absence of Cyber Game Discount machines as a competitive “feature” of their arcades.
In the end, Cyber Game Over became a cautionary tale among engineers on the kinds of oversights or mistakes that need to be caught in beta testing before a product gets released to market, and that a “soft” release in test markets can catch design flaws that the engineers might not have seen.
