TI have decided to produce their own genuine counterfeits
The moved the design to a more modern process. You can see that smaller lines sizes and shrunk dimensions can also reduce robustness of parts.
panic mode
Joined Oct 10, 2011
5,480
that would be total non-issue if the part number changed. but keeping the part number the same while changing specs (many changed for worse) is unforgivable.
Ian0
Joined Aug 7, 2020
13,317
Motorola did exactly the same thing to us back in the 1990s with the MJ15015. We'd been building a reliable power amplifier for years and suddenly they started blowing up. At first they blamed us, so we cut the tops off the transistors and found that all the ones that had blown up had a different die. I think they changed from hometaxial to something different.
After some argument they admitted it and "compensated" us by giving us a tiny discount on the MJ15003, but by then we'd cut the tops of enough transistors to find out that the MJ15015 was a higher voltage 2N3055, and the MJ15003 was in fact a 2N3773, which was much cheaper; cheaper than the discounted MJ15003.
hrs
Joined Jun 13, 2014
539
In Dave's video at 21:23 you see the new DS on the left. It says there are input protection diodes. According to this video there are not:
38,952
Probably planar, which generally had a lower secondary-breakdown value than the hometaxial (mesa) process devices.
So your experienced failures were probably due to secondary-breakdown in the planar devices.
There was a similar issue when the 2N3055 was changed from hometaxial to planar.
It would seem really unconscionable for a manufacturer to change the internal structure and thus the operating characteristics of a device without changing the part number in some manner (such as adding a letter to the end of the number).
But many have done it.
