MOC3010 Vs MOC3042 Help
RobbJohnson
Joined Dec 15, 2009
76
This circuit is switching 30 Volts AC with an input from a pic controller and has been working for years. I would like to know if the MOC3010 can be replaced with an MOC3042. the only difference i see is the
3042
OPTICALLY COUPLED BILATERAL
SWITCH LIGHT ACTIVATED ZERO
VOLTAGE CROSSING TRIAC
and the 3010
SWITCH NON-ZERO CROSSING​
TRIAC
I am not sure if this will effect the circuit. and help would be appreciated.
Robb
bertus
Joined Apr 5, 2008
23,000
That depends on what you are doing.
If you are trying to dimm the AC voltage, the 3042 will not work.
If you are only switching the AC on and off , the 3042 will work.
