It is not the value so much as the high wattage required that makes it a little impractical if using 12vdc source. It sounds as though 1.2Ω is about right for that motor.Thanks for your input on this. If I were to use a resistor (instead of the ammeter) what value should it be?
Michael
If you decide to use a 10Ω resistor, connect it in series with the motor from a decent 12vdc source, Ideally you would have two meters, one across the supply, the other across the resistor, but if only one, measure the voltage across the resistor at different points on the comm, with a locked shaft.Thanks Sensacell.
Ok Max, could you just explain how I set the circuit up with my motor to test?
Thanks
Michael
555-PWM Motor Control - MOSFET gets hot | Analog & Mixed-Signal Design | 30 | |
measuring 450nA | Test & Measurement | 8 | |
Measuring tiny currents | Test & Measurement | 27 | |
| Y | measuring time domain skew between two lines on a differential transmission | Test & Measurement | 1 | |
Measuring very low frequencys | Test & Measurement | 23 |
