It sounds like there is something wrong with your sensing setup. If you are getting only 3mV for your voltage measurement you need a longer length of cable or check you amplifier circuit.
Try to just measure across the full length of one cable to see what volts you get. I would expect even a multimeter would read something across one full cable unless you have really good cables.
