yes i have it gives an exact 1.0AHave you put your DMM in current mode in series to verify that your little current source is in fact outputting 0.999A? Those little cheap things can't be relied upon like a quality lab power supply.
Yes I get a negative reading when swapping the probes and a zero reading when one of the power source terminals are removed. The mV does increment proportionally as I increase the current.Swap the meter probes and see if your reading goes to the same but the reverse polarity. That can indicate it is a real reading, and not just noise.
When the power supply is turned off, the reading should be zero.
I did not understand clearly this part, so i should have a gain of how much ? Like 2 or 3 ?Now you have a confirmed reading for 1amp ( or whatever the test current was) so you can work out what gain the sense active rectifier amp needs to have to give you a good reading for the analog input of the Arduino.
NO. I only calculated the resistance of the weld cable (end-to-end) to come up with a theoretical maximum amp output of the machine based on internal resistance. I should not have done that; I think it was more confusing. You need the resistance of the 5.5cm section of weld cable, and the voltage drop across the 5.5cm section, and use Ohm's law based on that.So basically to get the amp reading we need the resistance of the weld cable (end-to-end) and a voltage reading from section of the cable and calculate the remaining with Ohms law.
I don't know what calculation you're referring to, and I don't know what your number 2.6 signifies. But I can guarantee you aren't getting anywhere near 2,600A from that thing.My calculation earlier gave about 2.6 or something in that range, would that be in Amps or mA. For Amps that would be very low, wouldn't it ? isn't that 2600Amps.
I can't make any sense out of what you have done with the schematic. You've taken the diode out of the feedback loop to U1 and now your output is garbled. it's no longer a rectifier and I don't know what it is now.Here is a more rectified schematic with a cap to smooth out the signal.
When you said "I only calculated the resistance of the weld cable (end-to-end) to come up with a theoretical maximum amp output of the machine based on internal resistance" you mean the max amps that the xfrmer can put out, correct ?I only calculated the resistance of the weld cable (end-to-end) to come up with a theoretical maximum amp output of the machine based on internal resistance. I should not have done that; I think it was more confusing. You need the resistance of the 5.5cm section of weld cable, and the voltage drop across the 5.5cm section, and use Ohm's law based on that.
