MCP3004 Fails when attempting to use more than one channel
bxdobs
Joined May 11, 2014
32
The original sketch was built to use an NTC Thermistor to monitor a remote mountaintop shack's ambient temperature ... this has been in operation for over 3 years ... we recently added some batteries with a Victron BP65 over/under voltage device ... because Victron doesn't provide an API for Bluetooth to allow monitoring of the Battery Voltage on the Pi, we were thinking we would just add a simple voltage divider to monitor the voltage using one of the unused Channels on the existing ADC. HOWEVER, for some unknown reason, the moment voltage is applied to the Vbat pin (top of the 100k pot) both Channel 0 and Channel 1 read 0V even though actual voltages of 1.2V and 2.2V respectively are being applied to the inputs of these channels ... the code listed below shows that these channels are being configured for single-ended use so completely stumped as to why this simple addition not only fails to provide any readings on Channel 1 but ALSO affects Channel 0.
Can anyone explain what I might be missing here?
The only change made was to add the 100k Pot which was pre-adjusted with a 20V input so the wiper reads 3.3V to ground ... this allows for the Pi to estimate the vBat as (ADC Val) / 1024 * 20 where ADC Val would be (Vchn1 / 3.3 * 1024) ... ADC read function unchanged
Example:
ch1 ip => 2.2V -> expected ADC reading => 683 -> estimated VBat => 13.4V
Instead, both Chn0 and 1 are returning readings of 0 until the VBat voltage is removed from the 100k pot
NOTE: pg and pgl referenced in the code are defined as follows: pg is a CLI process that allows a user to manually request current status ... pgl is a continuous loop process running in the background with a watchdog used to monitor and provide instant email notifications when readings hit or exceed set limits. An unused GPIO pin on the Pi is being used as a hardware Flag to ensure a CLI request doesn't collide with a Loop Request
Python Code:
#----------------- readADC( Channel# ) ---------------------------------------
# Microchip ADC MCP300X family has 3 variations; 2, 4 or 8 Channel 10bit A/D
# all 3 use a Serial Data Pin to Clock in Commands & Clock out Digital Data
# representing the Analog values
def readAdc(iChn): # MCP3004 has 4 Channels: 0 to 3
# ensure both pgl and pg don't attempt to read adc at the same time
bArf = GPIO.input(ARF[_PIN]) # is there a Read in Progress
while bArf == 1:
# wend
GPIO.output(ARF[_PIN], GPIO.HIGH) # set Read in Progress
# Datasheet says chip select must be pulled high between conversions
GPIO.output(CS[_PIN],  GPIO.HIGH)
# Start the read with clock high and chip select low
GPIO.output(CS[_PIN],  GPIO.LOW)
GPIO.output(CLK[_PIN], GPIO.HIGH)
# ADC commands are 5 bits long:
#   start bit = 1
#   single-ended comparison = 1 (vs. pseudo-differential = 0)
#   channel num bit 2 (MSB)     (for MCP3004 this is always 0)
#   channel num bit 1
#   channel num bit 0 (LSB)
# ie for single-ended channel 0 this command should be 1 1 0 0 0 or 0x18
iAdcCmd = 0x18  # base command for Channel 0
iAdcCmd |= iChn # add Channel to command
for iBit in range(5):
  # output MSB bit: HI or LO
  if iAdcCmd & 0x10: # is MSB HI?
   GPIO.output(MOSI[_PIN], GPIO.HIGH)
  else:
   GPIO.output(MOSI[_PIN], GPIO.LOW)
  # endif
  # Shift next bit to MSB
  iAdcCmd <<= 1
  # Send a clock pulse HI then immediately LO
  GPIO.output(CLK[_PIN], GPIO.LOW)
# next
iAdcVal = 0
for iBit in range(12):
  # Pulse clock pin
  # Read 1 data bit in
  if GPIO.input(MISO[_PIN]):
   iAdcVal |= 0x1
  # endif
  # Shift in next bit
  iAdcVal <<= 1
# next
# Divide by two to drop the stop bit
iAdcVal = (iAdcVal/2)
iAdcVal &= 0x3FF
# Set chip select high to end the read
GPIO.output(ARF[_PIN], GPIO.LOW) # clear Read in Progress
return iAdcVal
# end readACD
bxdobs
Joined May 11, 2014
32
Solved
Based on my review/analysis of the original code (which was copied, as is, from examples on github) VS the Microchip MCP3004 datasheet, suggests to me that: the CLK signal was coded incorrectly ... basically, if the clock edges are shifted to the left, this results in the Command being misinterpreted as a DIFFERENTIAL request (which could/would explain this failure ... attaching an unmatched voltage to ch 1 will wipe out both ch 0 and 1 readings)
The following analysis shows that the Command 11000 (0x18) is actually being read as 10000 (0x10) because the first/start bit is being lost due to incorrect clocking.
Code analysis:
1) CS is initially set low followed by CLK being set high
a) if CLK was low this rising edge is expected to be ignored because the start of MSB hasn't been given
b) if CLK was high then the Chip is still waiting for a falling edge to indicate the start of MSB
2) GPIO pin used for Din is set to the First BIT then the Command is Shifted Left (tossing the Start Bit)
3) CLK is set high (which is the state it is already at) so nothing changes
4) CLK is set low ... falling edge is now indicating to the chip that this is the Start of MSB
5) NEXT throws us back up to the top of the FOR loop
6) GPIO pin used for Din is NOW set to the Second BIT and Command is Shifted Left
7) CLK is set high resulting in a Rising Edge which finally Clocks in it's FIRST BIT (which is it's start bit)
As you can see the START bit has been lost ... the second bit is being interpreted as the first or Start bit ... and for Ch 0 the remainder of the Command bits will be 0
This Command puts Ch 0 and 1 in Differential mode ... as long as there is nothing (no voltage) on Ch 1 it won't cancel the value on Ch 0 but the moment an unmatched voltage is applied to ch 1 the differential mode will undoubtedly result in unexpected values
Corrected Code:
# ensure both pgl and pg don't attempt to read the ADC at the same time
# if CS is low then an ADC read is in progress
bArf = 0
while bArf == 0:
  bArf = GPIO.input(CS[_PIN])
# end while
#   start bit = 1
#   channel num bit 1
# Write Command
  # Write out 1 bit of data to Pi GPIO pin connected to Din
  else:
  # endif
  iAdcCmd <<= 1
  # Falling Clock Edge to move to next bit
  # Rising Clock Edge to clock in the data waiting on Din
# next
iAdcVal = 0
# Read Data
  # Rising Clock Edge to clock out the data from Dout
  # Read in 1 data bit from Dout
   iAdcVal |= 0x1
  # endif
  # Shift in next bit
  iAdcVal <<= 1
# next
# Divide by two to drop the stop bit (there is no stop bit!)
# leave this code in place to provide a buffer between reads
iAdcVal &= 0x3FF
return iAdcVal
# end readACD
twohats
Joined Oct 28, 2015
621
I'm replying in the absence of any response to your question.
I'm not familiar with pythons or MCP3004 .
My thoughts, is the MCP3004 getting enough current to function and what about adding some bypass capacitors?
It looks like the MCP3004 is a dual channel device, if that's the right wording.
Do each of the channels work if operated independently?
Have you tried powering the MCP3004 from a separate supply?
At least you have had a reply, even if it's rubbish. (The reply, that is).
Good luck...........
