MC34063AD negative voltage problem
riyashini
Joined Sep 18, 2014
20
Hi all,
i have designed the circuit using MC34063AD
to produce -5V at the output for +5V input.This -5V used to give the supply to multiplexer
i designed the circuit as per the datasheet
I have calculated the resistor R2 and R1 as per the formula
Vout=1.25(1+R2/R1)
Hence i got that R2=8.2K and R1=2.7K
L=100uH,Ct=470pF,R sense=240ohms
but i got only -0.2v at the output
can any one suggest me what was the wrong in my circuit?
Thanks in advance...
Alec_t
Joined Sep 17, 2013
15,119
Perhaps you've lost a decimal point ;). If Rsense = 240 Ohms the circuit will shut down if you try to draw more than a few mA output current. In the datasheet circuit Rsense = 0.24 Ohms !
riyashini
Joined Sep 18, 2014
20
k..thanks for your reply..actually the maximum output current will be given that 50 mA..
this 30mA is the current which has been reduced in the input side...is it right?
in my case i got that 43.5mA as the output current
