MaxHeadRoom
- Joined Jul 18, 2013
- 30,887
Did you read my post in #71?Then I came across Terrys_Dual_555_MC_2100_Driver_Circuit.pdf and on page 4 found the answer. I put a 330 ohm resistor in line with the pulse signal to the MC2100 and it fired right up. I have very accurate control from about 6% up to around 85% duty cycle. If you are above 0% duty cycle when you start the controller you have to go back to 0% and then forward before the motor and led respond. The easy workaround on this is a momentary button that interrupts power to the PWM module while you turn the board on. Then when you release the button the controller will ramp to the preset speed on the PWM module.
It appears some people are getting this to work without the resistor which would create the confusion of them actually working or not. At any rate, if you’re going down this path and not having any luck, read his article and try a resistor.
I mentioned that it requires an added series resistor.
The PWM pic based 20hz controller I developed, with two P.B. - Stop-Start functions will stop and re-start from zero RPM and ramp up to what ever the pot is previously set to.
Control is from 0rpm to motor rated RPM.
