MaxHeadRoom
- Joined Jul 18, 2013
- 30,869
That sounds more like mechanical problem?
That's what i was thinking, and assumed the motor given all other issues that usually cause this have been checked?That sounds more like mechanical problem?
Just checked. After walking on it yesterday and it slowing it tripped the circuit switch. Turned back on and looked to move the sensor and test that, but on starting the fuse blows again so not sure if the board has now the same mosfet issue. So it seems that perhaps the overload on the belt, perhaps due to fault with motor, leads to an overheat on the controller board leading to the mosfet issue? Are motor issues common?That's what i was thinking, and assumed the motor given all other issues that usually cause this have been checked?
That is what I read. And had a spare motor with the same symptomsMotor issues are rare, seems to point to a loading problem, ?
| Thread starter | Similar threads | Forum | Replies | Date |
MC2100ELS treadmill repair (3) | Technical Repair | 11 | |
| C | MC2100ELS-18W treadmill motor control circuit | Technical Repair | 3 | |
| M | MC2100 treadmill motor control circuit #4 | Technical Repair | 10 | |
| D | MC2100 Rev 2 treadmill - home circuit breaker blows | Technical Repair | 10 | |
MC2100ELS-50W Treadmill Controller | Technical Repair | 7 |
