MisterBill2
- Joined Jan 23, 2018
- 28,344
Given that the TS is a student it is likely that the application is not industrial. We do have some dimension information from post #12:Amar Ram never said what is the core in the electromagnet so it is probably air or a small rusty nail then it barely produces any magnetism even at the extremely high current.
one electromagnet = 1 mm diameter copper wire having 60 turns on a 7cm diameter cylinder of 2 cm
I have two electromagnet both the coils are connected in series to each other. so if we add together that would 120 turns of 1mm copper wire on a 7cm
So a 2cm diameter cylinder, but no clue if it is wood, plastic, paper, aluminum, or steel. The material will make a difference. And still no hint about the application.
Older computer power supplies required a load on the 5 volt output in order to stay active. I am not sure if that is still the case with those supplies providing 3.3 volts or not. That may matter a bit.
