I am seeking ideas, or thoughts, on how to make a cable connected touch pen invisible to the capacitive touch screen of a modern smartphone without mechanically lifting the pen (see illustration).
This is for a two axis (no lifting!) planer lego robot I am building to teach machine learning, in particular by showcasing how to control remote control a smartphone via various methods like "AI" (see picture). Unfortunately I don't have sufficient electro mechanical knowledge (software engineer) and am stuck now...
What I know:
My Thoughts:
I already plan to use a Raspberry Pi for the software aspect, but this device could drive some sort of circuit:
Thank for your input.
What I know:
- Modern smartphones use a Mutual Capacitance Touch Screen, sometimes called a Field Projected Touch Screen (▮). The system is the same from iPhones to Androids... though sensitivity varies.
- Taking the tip insert of a touch pen (○) and placing it on the screen triggers no touch.
- However, connecting the tip with a cable (⏚←◉▮) and that cable to even to highly isolated objects like rubber gets registered as a touch.
- This of course leads to an endless registration of a touch...
My Thoughts:
- (⏚ ←◉▮) — touch — When the tip with a cable absorbs / couples the capacitive field...
- (↯ →○▮) — no touch ? — ...can't we use some circuitry that puts somehow just enough "power" into the tip so it doesn't get registered by the sensing electrodes anymore? Like this:
