maglev (magnetic levitation ) prototype for graduation project
Lyncheese
Joined Jun 28, 2014
22
Of course its possible. Nothing is impossible as long as you're willing to build it.
read this link :
http://science.howstuffworks.com/transport/engines-equipment/maglev-train.htm
And you will get the big idea to get started.
It said that for this system you will need :
  • A large electrical power source
  • Metal coils lining a guideway or track
  • Large guidance magnets attached to the underside of the train
In short, a lot of electromagnetics.
Good luck !
Here's a maglev design that's totally passive.
That's a cool design. We use Halbach arrays to confine and focus ion beam surface charge on wafers for neutralization with a Xenon plasma. The problem with this method of levitation Earnshaws_theorem is that it requires relatively high motion (energy) to be stable in a simple configuration without mechanical constraint. To achieve stable levitation at 1 to 2 kilometers an hour must require some very strong magnets and a complex track coils but it should be possible to build a simple version using a fast moving 'car' with a cable constrain on the track.
http://gcep.stanford.edu/pdfs/ChEHeXOTnf3dHH5qjYRXMA/09_Post_10_11_trans.pdf
