LTSpice Simulation
KronosX
Joined Nov 15, 2017
None of the substrate pins are connected.
You need to go back and connect them (their should be a connection dot at the junction)
And specify a voltage for Vdd
Hmm all the substrate pins are connected to the source of the transistors. Which substrate pins are you referring? The voltage is not specified because I'm sweeping it as a variable from 0 to 10 Volts.
eetech00
Joined Jun 8, 2013
3,949
No…they are not.
When they are connected there will be a connection dot shown.
you Can confirm this by viewing the resulting net list.
