LTspice Simulation Time Problem.
Ahsanm445
Joined Sep 29, 2020
14
Hello All,
I am Working on Project in LTspice But My Simulation stops at a point I don't know what's the matter and does not process after even 2 days its 20ms simulation, Please look at the picture.It does not go forward than it please suggest me what should I do to resolve it?
Alec_t
Joined Sep 17, 2013
15,167
The models Eric is asking for are any which aren't in the default LTspice libraries.
Your png image does not show all the circuit, so isn't very helpful.
ericgibbs
Joined Jan 29, 2010
21,649
hi A445,
You did not include the NMOS model, so I used a generic model, it solves OK for me.
I suspect the problem is with your MOS FET model.
E
BTW: out2 is 0V reference
Ahsanm445
Joined Sep 29, 2020
14
hi A445,
E
Thanks for Your efforts,
Actually I want to Design a GaN Based Totem pole PFC and I have tried a lot of Models but NO one is Working Properly,Can You please Check my Latest Model It has also Some Issues Which I dont Understand Please Check it.
Bordodynov
Joined May 20, 2015
3,433
Your Q3 transistor is not used correctly.
One more tip. Draw your circuits more compactly. This is a typical disadvantage for novice users of electronic circuit simulation programs. This makes it difficult to see the whole circuit.
Ahsanm445
Joined Sep 29, 2020
14
Thanks for Your Important Comment.
I am Trying to improve this model, Can you please tell me the Problem with MOSFET Q3, Because there is No Q3 in my model so I dont know about MOSFET You are referring
ericgibbs
Joined Jan 29, 2010
21,649
hi,
Working thru the circuit, there are many errors and problems.
I would suggest you start again with the design, using a modular approach to each sub circuit, proving the function of a sub section as you go,
Also consider keeping a clean and tidy layout, so other can follow your work.
E
Bordodynov
Joined May 20, 2015
3,433
I do not like your scheme. The control signals are not correct. Not real element values.
In this case my calculation process is not interrupted and comes to the end. For acceleration I have changed some options.2020-10-22_13-23-04.png
