If you already have the cd4093b module then the error could be setup on the wrong path.This is what i get
The cap's values related with the oscillation frequency that you want.I think i have to figure more out on setting the cap's value. It's got charge and discharge to
Hola @ScottWangIf you already have the cd4093b module then the error could be setup on the wrong path.
it's not oscillating.internal schmitt trigger
Maybe you can see this.Hola @ScottWang
Could you elaborate? Cannot understand.
I was used the internal Schmitt trigger module and set the C1 Cap to 0.047uF, the results shown below.I've put it together on breadboard with real part's the cap is a 473 ( .047uF )
But I tried it with it's not oscillating.
I have the 4000 part's installed the ones I used worked but the 4093 I don't think I figured how to set the power pins up is what the error is
hi,Now to figure how to change L1 to a transformer
by Jeff Child
by Robert Keim
