Looking for a good high voltage MOSFET for a PWM design
Hamlet
Joined Jun 10, 2015
560
You could look at the average (filtered) voltage across the MOSFET.
If it stays at zero for a significant length of time, indicating a shorted MOSFET, then you could use that to open the relay.
Below is the simulation of a circuit to do that.
The NO relay contact is closed when there is power and a PWM signal at the MOSFET drain.
The PWM source signal is filtered by R1C1 and goes low with a delay [V(1)] after the simulated PWM gate signal stops and goes high (simulating a shorted MOSFET).
This turns off transistors Q1 and Q2, opening the relay and power to the motor some 9 seconds later.
As long as the PWM signal average is at least 1.5V, the relay will stay pulled in.
C1 is connected to the +12V so that [V(1)] will go high and energize the relay when power is first applied.
(Note C1 polarity).
D1 clamps the V(1) voltage to ≈13V maximum (about 0.7v greater than the 12V supply).
Okay, built and tested. I found a sacrificial mosfet in my junkbox for the test.
The relay engages as soon as power is applied, and switches off when
power is removed. For the test, I increased the pwm until I was at max rpm,
then I increased the load until the mosfet popped, & then I started counting
the seconds. After I got to 15, I yanked the plug because I didn't want to wait
any longer for the protection circuit to kick in, and having either my motor or pump damaged.
It was really screaming.
