LM741 Op amp - what is the maximum input current?
henrylavery242
Joined Aug 8, 2024
74
Why? The opamp is superfluous anyway. It serves no purpose.
Why do you think you need it?
Hint: If your signal generator could only output 1mA, you would need a buffer.
So you recon it will work without the op amp anyway? Would it work with the op amp buffer,
35,281
Let us put it this way.
This equation represents Ohm's Law:
I = V / R
There are three variables, I, V, and R.
If two variables are known, then the third variable is determinate. It cannot have some arbitrary value.
If I and V are fixed, then R must be fixed.
If V and R are fixed, then I is fixed as well.
henrylavery242
Joined Aug 8, 2024
74
The impedance of my signal generator can be adjusted from 5 ohms to 650 ohms as it states of the data sheet what would you set it to for the best matching
dl324
Joined Mar 30, 2015
18,501
Would 1
Would 1uA be too large
I'd go higher; 2-3uA.
Have you even bothered to look at the datasheet?
You want the input voltages to be at least an order of magnitude greater than 7.5mV (worst case input offset voltage). You want the input current to be at least an order of magnitude greater than 0.2uA (worst case input offset current).
henrylavery242
Joined Aug 8, 2024
74
Yes I looked, I just don't know how to interpret it very well. Could you help please?
Is this the current that I would need at the non inverting pin?
If I input a 2V signal into the LM741 would it work correctly?
henrylavery242
Joined Aug 8, 2024
74
The input resistance of the LM741 is 2 MΩ.
If you apply 2 V on the input, Ohm's Law gives the current.
I = V / R
I = 2 V / 2 MΩ = 1 μA
Too high or too low is irrelevant. You don't have a say in the matter.
Yes I worked out this value, again thanks for the help with this . All I would like to know is would I be able to use the op amp to buffer the 2V signal from the signal generator please
sparky 1
Joined Nov 3, 2018
1,218
What's all this 741 load stuff by Bob Pease, Santa Clara
Effect of Heavy Loads on Accuracy & Linearity of Op Amp Circuits (Rev. B) (ti.com)
A nice triangle wave input and for output if there is distortion reduce the gain and it has 10mA for this test.
Absolute Maximum that the LM741 will dissipate is 500mW by American standards,
when it's that hot the output suffers it is rough, not shown, and would not pass most quality assurance departments.
And not every application needs an undistorted wave, accuracy or linearity.
Max Supply +/- 22Vdc, the Nominal supply +/-15V* is the industry standard supply voltage. However +/-22Vdc can be used.
See note *
(5) For supply voltages less than ±15 V, the absolute maximum input voltage is equal to the supply voltage.
LM741 data sheet, product information and support | TI.com
35,281
That I cannot answer. What do you mean by buffer?
The signal generator is good to 20 mA, i.e. a 200 Ω load.
Can the LM741 do any better? I don't think so.
henrylavery242
Joined Aug 8, 2024
74
Sorry I think I have miscommunication. English is not my first language. Please see the datasheet. I worked out my input bias to be 1uA. Am I correct in saying the op amp will work correctly because it is within this range?
I intend to apply the 2V signal, to a LM741 buffer and then to my other circuit.
35,281
There is no improvement to using the LM741 op amp.
Why not just connect the output of the signal generator to your "other circuit"?
BobTPH
Joined Jun 5, 2013
11,674
It depends. A 741 will distort a sine wave above 9KHz.
You still have not told us:
1. why you think you need to use a buffer
2. why you think you need to match the impedance
3. why you think a buffer would do that
All of three of those assumptions are wrong. So, if you want to learn something, try to understand why they are wrong.
You need to understand basic DC circuits before you can even start with AC circuits like filters.
henrylavery242
Joined Aug 8, 2024
74
I think I will need a buffer circuit to impedance match the filter to the signal generator which has an impedance of between 5-640Hz (This can be adjusted)
As the frequency varies due to the RLC band stop filter this will change the impedance of the circuit. This is why I think I require the buffer amplifier.
A buffer amplifier has a high impedance input and a low impedance output. This will ensure that the signal isolated from the effects of loading between circuit stages
Would this be incorrect?
henrylavery242
Joined Aug 8, 2024
74
Am I correct in saying that the buffer amplifier will work though because it within the maximum of1.5uA as stated on the datasheet.
