LM741 Op amp - what is the maximum input current?
35,117
So to clarify, if my 2V signal generator is fed directly into an LM741 with a 2MOhm impedance. The current drawn will be 2v÷2mOhm=0.000001A
I can give you a straight answer but at this stage, you need to figure out things like this on your own, given that I have already given you a complete explanation.
BobTPH
Joined Jun 5, 2013
11,638
Yes, that is correct.
But why don’t you tell us what you are trying to do.
What are you trying to drive with yor signal generator.
At what frequency?
Why do you think you need impedance matching?
Why do you think a ‘741 will do that?
henrylavery242
Joined Aug 8, 2024
74
At what frequency?
I am trying to buffer a 2V signal from an oscilloscope into an RLC BSF. I need to know the maximum current that can be input into the non inverting terminal of a LM741
BobTPH
Joined Jun 5, 2013
11,638
Okay, thank you for the circuit.
Your signal generator can drive a 50Ω load. Your RLC circuit had 300Ω in series. So the signal generator can drive it directly without a buffer.
I would still suggest that you try to answer my questions because they will demonstrate your misconceptions that we can help you correct.
SamR
Joined Mar 19, 2019
5,535
You don't input current, which is in Amps by the way. The device uses current to create power. How much that it uses is dependent on the component and the load on the component, not the power supply.
SamR
Joined Mar 19, 2019
5,535
The PDF states that the absolute MAX input voltage is +/-15V. Is your AC source greater than that limit? If so, then a resistor is needed to drop the voltage to below the MAX input limit.
henrylavery242
Joined Aug 8, 2024
74
Hello, the input signal generator outputs 2V directly into an LM741 buffer. I just wanted to know if it would work? Or would the current be too large ?
BobTPH
Joined Jun 5, 2013
11,638
Just get the idea that you have to control current into the opamp input out of your head. You control the voltage. If the voltage is within range, the current will not do any harm.
BobTPH
Joined Jun 5, 2013
11,638
Why? The opamp is superfluous anyway. It serves no purpose.
Why do you think you need it?
Hint: If your signal generator could only output 1mA, you would need a buffer.
henrylavery242
Joined Aug 8, 2024
74
Just get the idea that you have to control current into the opamp input out if your head. You control the voltage. If the voltage is within range, thw current will not do any harm.
So I don't need to worry about controlling the current? So if my voltage is within the range the buffer will work?
Looking at my diagram, the 2V input signal from the signal generator will be correctly buffered ? In the configuration I have drawn?
