LM741 Op amp - what is the maximum input current?
dl324
Joined Mar 30, 2015
18,472
It's going to be quite low.
From National Semiconductor:
Why do you think you need a large current into an input?
henrylavery242
Joined Aug 8, 2024
74
What is the maximum current I can input into the LM741
Not sure how to draw the circuit. I basically need to impedance match a signal generator with a RLC BSF.
I need to use a LM741 op amp to do this but I realise the current may be too large to be input directly.
Could I have help on how you would draw this circuit please. Sorry I'm a amateur
35,190
N
OHHHHHHH right am I being stupid then?
My input is 20mA
No. Not stupid, just not knowledgeable.
Your input is not 20 mA. Where did you get that information?
Ohm's Law
Here is how Ohm's Law works:
I = V / R
If V = 10 V, R must be 500 Ω in order to have a current in the circuit loop of 20 mA.
henrylavery242
Joined Aug 8, 2024
74
So my signal generator outputs 2V and 20mA could I feed this signal directly into the non inverting pin of the op amp? Or is the current too high,
35,190
I am using a Rhode and Schwartz apn62 signal generator. I just got told it was 20mA so should probably check the value
The generator puts out 2 V with a maximum current of 20 mA.
If you put 2V into a 1000 Ω load, the generator puts out 2 mA.
If you put 2 V into a 100 Ω load, the generator puts out 20 mA.
Do you see how the output current depends on the load resistance, not on the maximum capability of the generator?
It also means that don't try to use a load resistance lower than 100 Ω. You will exceed the maximum capability if the generator.
henrylavery242
Joined Aug 8, 2024
74
Yes so my maximum current will be dependant on the impedance of the LM741 op amp then? As I input the 2V straight into the buffer amplifier?
35,190
This is a common mistake made by beginners and it applies to all voltage sources, for example, batteries and power adapters.
Suppose you have a 9 V battery capable of outputting 200 mA. It does not deliver 200 mA unless you ask for it.
Suppose you have a USB 5 V charger capable of outputting 2 A. It does not deliver 2 A unless you demand it.
henrylavery242
Joined Aug 8, 2024
74
So to clarify, if my 2V signal generator is fed directly into an LM741 with a 2MOhm impedance. The current drawn will be 2v÷2mOhm=0.000001A
