AlbertHall
- Joined Jun 4, 2014
- 12,663
Are you really, really sure?No everything is connected, base, collector, emitter .
Measure the resistance between LM317 output and the base of one the 2N3055.
Everything is " physically connected " , but when trying to measure, LM317 Output resistance / transistor base with range 400, 40K, 4M : OL so not connected !!!!!!!!!!!!Are you really, really sure?
If you measure very high resistance between LM317 output and the base(s) of the 2N3055 then they are not connected even if they look like they are. Check that connection very carefully.Sufficient to be sure transistors are ok?
Hi Albert,If you measure very high resistance between LM317 output and the base(s) of the 2N3055 then they are not connected even if they look like they are. Check that connection very carefully.
That slowly rising output voltage is exactly what I would expect if that connection was missing. Concentrate on that.
| J | Power supply with LM317 Advices Needed - Part 2 | Power Electronics | 18 | |
| J | Power supply with LM317 Advices needed. | Power Electronics | 38 | |
LM317 reg., input vs output | Power Electronics | 29 | |
Combining LM2596 buck converter module with LM317 Linear Regulator | Power Electronics | 40 | |
LM317 LDO design excercise | Homework Help | 18 |
