LM317 power supply issue
jm-a
Joined Oct 20, 2010
111
I don't know what that means but generally, you want to measure the voltage on the 3-terminal regulator's input, adj and output pins (not copper traces) and go from there.
Hi dannyf,
I've still the same measures ....
Joined tests taken on pot leads, and always 34,4V on both leads A and B, and also 0V from A to W leads....
Next step?????
Thanks a lot.
jm
jm-a
Joined Oct 20, 2010
111
For 0 kOhm from adj to ground, you measure 34.8V. One of those two is wrong as you cannot get 34.8V across a short circuit :confused:
Hi Albert,
Next step?????
Thanks a lot.
jm
AlbertHall
Joined Jun 4, 2014
12,638
Just to clear, if you measure the voltage between A and ground, or between B and ground, they both read 34V?
From the schematic, one of them is supposed to be connected to ground so CANNOT have 34V to ground.
Please connect negative meter lead to ground then, with power off, connect positive meter lead to each of A and B and record the resistance reading.
Then select the voltage range on the multimeter, turn the power on, and connect the positive probe to each of A and B and record the voltage.
jm-a
Joined Oct 20, 2010
111
Hi Albert,
So V A / ground = 34.23V Resistance: 1.14 MOhm - MegaOhm or MegOhm, don't know the right unit? -
V B / ground = 0V Resistance: 0 MOhm Point B must be grounded ?
Last measures were between A and B, not between these points and ground; of course it seems to be useless.
And also between wiper and point A .....
Apologies if my crude schematic, induced you in error.:confused:
Thanks a lot .
AlbertHall
Joined Jun 4, 2014
12,638
So the pot is open circuit - which would cause all the other effects.
Point B to ground 0 ohm, point A to ground 1 Mohm, therefore the pot must be at least 1 Mohm and not the 4.7k it is supposed to be.
jm-a
Joined Oct 20, 2010
111
I'm going to desolder it, control it's resistance and then replace it.
Thanks.
jm
dannyf
Joined Sep 13, 2015
2,197
Which is what?
No idea what A, B, or W is.
I think you are making it quite hard for others to help you, by assuming others know what you mean. We only have the schematic to go by. So a much easier approach wo7ld be to refer, always, to the schematic when providing information. Otherwise, you provide more confusion.
jm-a
Joined Oct 20, 2010
111
Hi albert,
As i am also a lucky guy, my 4.7KOhm has burnt !!!!!!!!!!!!!
Going to buy others, as evidently no spare parts in my box.
Thanks for your help, albert and others members of this forum.
jm
AlbertHall
Joined Jun 4, 2014
12,638
When you fit a new one, set it to the mid-position and don't move it until you have a correct output voltage of around 15V. This will prevent the new pot being damaged if there is another fault.
jm-a
Joined Oct 20, 2010
111
Which is what?
Hi Danny,
Points A, B , W are points of pot schematic - see picture joined -
I'm trying to be clearer for all, next time.
Thanks alot.
jm
jm-a
Joined Oct 20, 2010
111
I choose 3 '' good pot " , i hope so ...
First: http://www.reichelt.de/6mm-Pots-mon...RTICLE=88204&GROUPID=3135&artnr=PO6M-LIN+4,7K
Second: http://www.reichelt.de/Multi-Turn-P...ARTICLE=54295&GROUPID=3138&artnr=P4W-LIN+4,7K
Third: Multiturn, costly, but for precise setting, worth money?
http://www.reichelt.de/Multi-Turn-P...LA=2&ARTICLE=2545&GROUPID=3138&artnr=534-5,0K
Is it good components for this use?
Thanks a lot.
jm
jm-a
Joined Oct 20, 2010
111
Hi all,
Bought and received new pots, and still the same end: burnt with white smoke!!!!!!!:(
With pot set initially ad mid course, output display was: 33.6V.
Joined a short resume of measures.
I've still 4 more pot, but i don''t like black smoke ...............:)
Thank for your help.
jm
jm-a
Joined Oct 20, 2010
111
Hi all,
I desoldered the pot to verify resistance, or short circuit ....
5,45 KOhm from pt A to B
Resoldered it :
A to ground 12.8 KOhm B to ground 0 Ohm
Power on :
A to ground 34.58V Wiper to ground 32.3 V B to ground 0V
Also 34.4 V output display.
And now ?
Thanks.
jm
bertus
Joined Apr 5, 2008
22,978
How did you measure the Vref?
In the table you say Vout = 33.7, Vadj = 33.18.(for 0Ω and 2.3 kΩ).
When I subtract 33.18 from the 33.7, I get 0.52 and not the Vref you mention.
Please measure the voltage at the LM317 output itself.
Bertus
