LM317 power supply issue
jm-a
Joined Oct 20, 2010
111
Are you really, really sure?
Measure the resistance between LM317 output and the base of one the 2N3055.
Everything is " physically connected " , but when trying to measure, LM317 Output resistance / transistor base with range 400, 40K, 4M : OL so not connected !!!!!!!!!!!!
jm-a
Joined Oct 20, 2010
111
Only check Vbe, Vce, Vbc with diode check function of dmm, all seems correct. Sufficient to be sure transistors are ok?
AlbertHall
Joined Jun 4, 2014
12,638
If you measure very high resistance between LM317 output and the base(s) of the 2N3055 then they are not connected even if they look like they are. Check that connection very carefully.
That slowly rising output voltage is exactly what I would expect if that connection was missing. Concentrate on that.
jm-a
Joined Oct 20, 2010
111
Hi Albert,
You are absolutely right; in fact one solder seemed good but in fact, was forgotten on pad....
Checked with dmm, soldered it and works fine: 13.6V display output.
Next step, remove 2W 2.2 KOhm resistors and replace it by precise potentiometer, to get psu fully functionnal.
Thanks a lot for your patience Albert, and replies.;)
Thanks a lot also for all members of this forum, and augustin for his french message.
Sympa augustin, ton joyeux 14 Juillet.:)
jm
