this is the link to the product sir.Link?
You need to let them soak at 3.6v until the charge current has dropped to a low level, else they won't be fully charged, maybe only 70%
https://www.aliexpress.com/item/32721972694.html
will it be fine?
The undervoltage cutoff at 2v is too low. The overcharge voltage of 3.65v is good, but its not clear if it stops charging at that voltage or starts cell balancing. There's no mention of balancing current and i don't see large resistors per cell that are typical of a balance circuit.this is the link to the product sir.
will it be fine?
Hmm.The undervoltage cutoff at 2v is too low. The overcharge voltage of 3.65v is good, but its not clear if it stops charging at that voltage or starts cell balancing. There's no mention of balancing current and i don't see large resistors per cell that are typical of a balance circuit.
In short, I can't say. Not enough information.
| L | Charging series lithium batteries | General Electronics Chat | 11 | |
BMS not working properly | Technical Repair | 6 | |
Charging lithium batteries | General Electronics Chat | 14 | |
| D | how build a simple charger | Homework Help | 8 | |
Charging lithium ion batteries with laptop charger while supplying power to the load. | Power Electronics | 5 |
