Using a Lithium battery pack and solar charging.
gray-b
Joined Aug 4, 2025
89
I have a lithium 12v battery pack 3S3P, which has an inbuilt (shrink wrapped) battery control pcb.
The pack has 2 cables one for going to the load (output cable), and the other for charging it up (input cable). The charging is normally done by a mains plugin charger.
My plan is to use this in a control box to power up some circuitry.
I have a 18v solar panel that will feed into a new solar/lithium charger pcb.
But I am unsure as to whether I can feed that directly into the one input cable via the battery control pcb.
Any thoughts or ideas please.
Irving
Joined Jan 30, 2016
5,195
Standard voltages for a 3S lipo charger, so it should be plug and play. The battery will decide on its own charge rate, as long as the charger can provide at least 1A, so this is fine. Just make sure they are compatible connectors and same polarity, typically centre is +ve.
gray-b
Joined Aug 4, 2025
89
Yes, many thanks.
I always get mixed up with which is the male/female ends of the barrel power plugs/sockets.
I have accidently plugged both the battery plug/socket into each other. Nothing happened, I dont think.
Irving
Joined Jan 30, 2016
5,195
The ones with a hole (female/plug) should always be OUT and the ones with a pin (male/socket) should always be IN. See this Wikipedia article.
As I would expect; since voltage OUT from pack is < required voltage IN to start charging (otherwise battery would be charging itself!)
