Hi,23 posts after the OP left the building (and counting).
The age old question, is "good enough" ok if the customer is satisfied, or is "good enough" an enemy of the best?
Seems there was a problem like that in my calculus class a few eons ago.Take a cone of height H and diameter D.
Now spiral a wire about this N times, evenly spaced.
What is the length of this wire?
My approximation is probably close enough, but I wonder if there is a simple answer to this.
(Note: I am NOT planning how to light my Christmas Tree. No, not me.)
I don't either.Hi,
It's called social interaction.
Someone enters the room and proclaims, "The president has been shot", then leaves. Discussion ensues.
I dont see a problem with that ...
"Concerned" is an interesting way to not answer my question....not sure why you would be so concerned, ...
I thought my question was completely clear....but you could elaborate.
Thank you, but I've been around a long time, I've seen how it works. It was a question based on the competing signatures of two long time members. But you've been around a long time, too, and probably knew that.Once a discussion starts it is not unusual for the person that started it to bow out, if it is something of interest to others they will continue to talk about it. We are not just here to answer questions we have our own interests too.
Hi,Seems there was a problem like that in my calculus class a few eons ago.![]()
Hello there,One of ideas of calculus is to divide the spiral in `n` rings, where n is turn count. As those are ideal rings with length =pi()*D, then there is not so difficult to sum it all. Yet there is factor making a mistake, that is vertical inclination between each turn beginning and ending - however, knowing the each turn `ideal` length (what minute ago You calculated) You may add the vertical component assuming that coordinates are spiralized along the wire, thus the wire `seems` straight. Allpying the Pythagor pants theorem, You get `real lenghth` =SQRT(`ideal lenght`^2+`vertical distance between each turns`^2). Just make an exercise with an Excel.
Bold type remarked by me.Once a discussion starts it is not unusual for the person that started it to bow out, if it is something of interest to others they will continue to talk about it. We are not just here to answer questions we have our own interests too.
Don't just tell us how you would do it; work it out and show the result you get from this approach.Look at the cone and cut it open and flatten it.
Now you have a pie shape.
you know the exact position of each wire that position stand for that part of the pie.
This wire is not strait it will shift each wire thickness over that part of the pie.
If however, the wire thickness is a fraction of the move you may assume an error close to zero.
This should be my approach.
Picbuster
Hi,Look at the cone and cut it open and flatten it.
Picbuster
oops a red face
Hi again,Between MrAl / Mr Chips and Picbuster there is a factor of 3 into play. Could that be suggesting a possible mistake thus a subsequent correction?
Not sure what to suggest myself.
I'm guessing someone forgot to divide by (pi)Between MrAl / Mr Chips and Picbuster there is a factor of 3 into play. Could that be suggesting a possible mistake thus a subsequent correction?
Reports of my demise have been greatly exaggerated.23 posts after the OP left the building (and counting).
I've been wondering how the various answers between 25' and 27' would have influenced your shopping.Reports of my demise have been greatly exaggerated.
I'm still following the thread, but since I got a good nuf answer to get the lights on my tree I'm happy to watch people better at math than I am solve this.
