Do RF lines have to be a certain length? Based on Frequency?
tdengineer
Joined Oct 21, 2025
38
rf length.pngMy RF is 2.4ghz
I have a LC pi filter and a low pass filter ic leading to the 50 ohm antenna
Everything is matched to 50ohm impedance.
Do i need to worry about line length and what distance between stitching vias should i be using to block emi
simozz
Joined Jul 23, 2017
170
Yes. At these frequencies (GHz not ghz) we talk about transmission line theory, length and width play a crucial role. Layout and stack too.. Length depends on substrate dielectric constant (and frequency of course).
Avoid corners as much as possible in traces, use curves instead. For distance of vias and proper stack, might check some RF PCB guidelines application notes for WiFi/BT modules using these frequency.
28,356
Often, for high frequency signals on PC board assemblies, there is an effort to configure those high frequency traces as transmission lines. There is a lot of information available on that subject. But not from me.
drjohsmith
Joined Dec 13, 2021
1,654
View attachment 359124My RF is 2.4ghz
the impedance of the via is probably going to be greater than the impedance of the pi filter.
is the red trace rf also ? why the split ?
the tracks look very narrow for 50 ohms you state.
whats the ground / power plane look like ? is there one below these tracks ?
sparky 1
Joined Nov 3, 2018
1,218
The resonance is related to length, it becomes more critical as the frequency increases. We can add 3% to the length, better to to be long than too short.
an approximation on FR4 microstrip usually microwave or uhf
Free-space wavelength at 10 GHz: 0.030 m
Guided wavelength (ε_eff=2.8): 0.018 m
Half-wave resonant length: 0.009 m (0.9 cm)
Quarter-wave resonant length: 0.004 m (0.4 cm) ----- 0.157 inches
Free-space wavelength at 1 GHz: 0.300 m
Guided wavelength (ε_eff=2.8): 0.179 m
Half-wave resonant length: 0.090 m (9.0 cm)
Quarter-wave resonant length: 0.045 m (4.5 cm) ----- 0.1.77 inches
compared to 100MHz like a fm radio antenna
Free-space wavelength at 100 MHz: 3.000 m
Guided wavelength (ε_eff=2.8): 1.793 m
Half-wave resonant length: 0.896 m (89.6 cm)
Quarter-wave resonant length: 0.448 m (44.8 cm)----- 17.638 inches
compared to 1 Mhz long wire antenna
Free-space wavelength at 1 MHz: 300.000 m
Guided wavelength (ε_eff=2.8): 179.284 m
Half-wave resonant length: 89.642 m (8964.2 cm)
Quarter-wave resonant length: 44.821 m (4482.1 cm)----- 1764.6 inches
