Length Measuring Mechanism
fahadatnet
Joined Dec 22, 2004
9
Hi
I have to built a bot which can measure the length of a path,which will be a white line path.
The problem is that how to measure the path accurately/precisely Coz the path may be circular or any other shape so the line follower bot will not trace the exact path which will result in an error.
So please tell me two things
1. some mechanism to measure the length of the path &
2. an algorithm which will minimize the errors(Extra length measurement).
Eagerly waiting for reply
THANKS
mozikluv
Joined Jan 22, 2004
1,435
Originally posted by fahadatnet@Nov 26 2005, 05:37 AM
Hi
THANKS
[post=11945]Quoted post[/post]​
hi,
"I have to built a bot" what's a bot?
have you done a google search on this?
JoeJester
Joined Apr 26, 2005
4,390
I think by bot he means robot.
It's a carry over from chat rooms where robots are used to get you to go to some subscription site.
But, I could be wrong.
mozikluv
Joined Jan 22, 2004
1,435
hi
i will presume that you will be using the wheel of the robot to do the measuring. then just place a magnet on the wheel rim to trigger a reed switch. everytime the magnet passes the reed switch that would constitute your 1 revolution. the output connected to an up/down counter logic device mand the result displayed on a 7 segment LED display. to make things easy for the counting you have to choose a wheel that has 1 revolution of 1 inch distance. that way whatever is displayed is now you actual distance measured.
if you can't have that kind of wheel, then other devices has to be employed to convert the count into actual distance.
moz
