About 1ft8inchesHello,
How long is your strip?
It says 0.833 A for each meter of strip.
I did!Didn't anybody else see that???
Which is exactly what have here.I am just accustomed to binning LEDs with a series resistor or iset resistor
Section 7.3.4 of the TI data sheet is why I put it thereThe circuit in post #29, as shown, will apply about 150volts DC directly across the diodes. That is due to that diode, "D1" shunting the regulator device. Didn't anybody else see that???
"7.3.4 Blocking Diode A blocking diode is required between the drain of the switch (DRAIN) and the anode of the LED stack.Section 7.3.4 of the TI data sheet is why I put it there
| A | WS2811 drive 5V LED strip | Analog & Mixed-Signal Design | 7 | |
Strip Sensor question | Analog & Mixed-Signal Design | 6 | |
| O | How efficient are LED strip lights? | General Electronics Chat | 10 | |
Need Help With Identification | General Electronics Chat | 14 | |
Switch for 12V strip LED using MOSFET | Analog & Mixed-Signal Design | 16 |
