LED Indicator for 120VAC and 24VAC Applications
cwella
Joined Jul 9, 2026
25
Hi everyone,
I’m looking for advice on the best way to run a general-purpose red LED indicator from a 120VAC supply and another LED indicator from a 24VAC supply.
I want a safe and reliable solution and was wondering whether it’s better to use pre-made AC LED indicators or build a circuit using components such as a rectifier and current-limiting resistor.
For the 120VAC application, I understand that a standard LED cannot be connected directly to mains without proper protection. For the 24VAC application, would a simple rectifier and resistor setup be suitable?
Any recommendations for suitable components or circuit designs would be appreciated.
Thanks!
12,196
Can't do schematics right now, so an all-text response.
The classic minimal circuit for both voltages is one series resistor to limit the peak current, plus one diode in anti-parallel with the LED to clamp the reverse voltage. Anti-parallel (or reverse-parallel) means the LED cathode is connected to the diode anode and the diode cathode is connected to the LED anode.
LED peak current is determined using Ohm's Law. Don't forget to subtract the LED forward voltage (Vf) from the mains peak voltage. Also, calculate the peak power dissipated in the resistor (using either Watt's Law or Joule's Law) and use a resistor rated for twice that amount.
Note that this is a half-wave rectifier, so the LED will be flashing at 60 Hz. This might be noticeable, particularly in you peripheral vision. To double the flash rate to 120 Hz, replace the single diode with a diode bridge.
dl324
Joined Mar 30, 2015
18,426
There's nothing safe about a DIYer connecting an LED to line voltage.
This circuit will work for both mains and 24VAC. Just size the resistor appropriately to give a few mA.
For line power, I'd use a 1W resistor.
You could also replace D1 with another LED.
cwella
Joined Jul 9, 2026
25
Thank you everyone for the responses and helpful suggestions. I appreciate you taking the time to share your knowledge and advice. It has given me some useful ideas to consider.
cwella
Joined Jul 9, 2026
25
Many small resistors are not voltage rated for 170V, the peak of the power line voltage of 120v. You might want two resistors in series.
Good point, I appreciate you mentioning that. The voltage rating of the individual resistors is definitely something to consider, not just the resistance and power rating. Using two resistors in series would help share the voltage stress and give a better safety margin, especially with the 170V peak from a 120V AC line. Thanks for the reminder, it's a small detail that can make a big difference in reliability.
dl324
Joined Mar 30, 2015
18,426
Most resistors are rated for 200V.
From Yaego for metal film resistors:
The resistors above that end with 'S' are the smaller variants that are rated for higher wattages:
Additionally, for AC voltages, it's the RMS voltage that matters for power calculations. If he rectified and filtered, that would be different, but OP was talking about AC voltages.
EDIT: SEI data:
Pyrex
Joined Feb 16, 2022
515
For 120VAC operation choose R1 220 Ohm 0.5W, C1 220nF 400V, C2 220uF 6.3V.
For 24VAC operation components R1 R2 C1 can be replaced to 2.4kOhm 0.5W resistor.
Capacitor C2 eliminates Led flickering
dl324
Joined Mar 30, 2015
18,426
4.1 mA (RMS) or less.
I wouldn't be averse to operating a 1W resistor at 0.6W; maybe even a little higher. I've never been a fan of the 50% derating style. Resistors are specified for 100% of the rated power at 70C ambient. Sure, that's an uncomfortable temperature for fingers, but electronic components aren't fingers.
I'll have to run some experiments operating resistors at uncomfortable temperatures.
12,196
I hope you are not saying that *all* resistors are built to this one spec. Many components intended for rugged environments are specified at +85C, +100C, and +125C.
Note that because +70C is the ambient air temperature around the resistor and not its surface temperature, the surface temperature can be much higher - more than enough to cause real pain and blistering.
Also, the rest of the spec is time - how long the resistor is rated to operate under those conditions at a specified MTBF. This is what changes bigly when the device dissipation is reduced. A part rated for 1000 hours at +70C ambient while dissipating 1 W might also be rated for 10,000 hours when dissipating 0.5 W. It depends on other factors such as materials, construction, and size.
A common rule of thumb for electrolytic capacitors is that the lifetime doubles with each 10C reduction in temperature. So a cap rated for 1000 hours at +70C is rated for 2000 hours at +60C, 3000 hours at +50C, etc. Same for fan bearings.
12,196
Did you mean 70˚F?
No. +70C ambient is a very common upper limit environmental specification for consumer-grade electronic components. Not good for people, but easy to achieve in power electronics, and just about anything with tubes / jars / empty-state devices. One of my older cable-TV boxes runs so hot it is uncomfortable to touch. A common "industrial" spec is +85C. Automotive specs are often this high or higher, and the US military is famous for "-55C to +125C". The lowly 2N2222 is characterized up to +150C, and many power MOSFET's are specified up to +175C. In automotive stuff, sometimes the temperature range spec for the interior is higher than for under the hood. Think about a dark-colored car with a black interior, windows up, sitting in a parking lot in Arizona in August. T.h.a.t is hot.
For semiconductor devices, you got-got-gotta read the datasheet. The temperature spec can be for the ambient air, the case temperature, or the junction temperature. There is a reason why thermodynamics is a required course in undergrad EE. The #1 killer of semiconductor devices is not transients / ESD; it's heat.
