See post #66. Those strip lights are exactly as you propose each have there own resistor with each resistor LED pair wired in parallel to the 12V bus. The real problem for me, is SMT's. The 3528 LEDs are as small as I believe I can successful solder. This will be my first attempt as soldering SMT's. I did order an SMT practice kit from Amazon that I will try to solder before I try this one, but the resistors and LEDs are tiny, I have my doubt even getting 50% of them soldered correctly. But who knows, I may surprise myself. At this point if I were to try that it would have to be through hole resistors with 3528 size LEDs. I do have room for through hole resistors.You have 36 individual LEDs, right?
I am suggesting putting each of them in series with a resistor and then putting all 36 of those in parallel to your 12V.
You suggested putting 4 in series with a resistor then putting the nine strings of those in parallel. The reason for doing that is to reduce power used. But you don’t want to reduce power used only so you can waste it in a parallel resistor that gets very hot. Wasting at least some of the power in 36 small resistors is preferable because the heat is spread around.
SMT resistors are small and cost about a penny each.
Ideally, you could find inefficient LEDs, where, to produce the brightness, you need would take enough current to satisfy the current monitor and no parallel resistor would be needed.
You could also run higher power LEDs that way and use a neutral filter to reduce the light that gets through.
It just irks me that your solution needs a high power resistor that is large, expensive, and gets very hot. I am trying to find a solution that does not require that.
Could I really find LEDs as inefficient as an incandescent? And fairly good size that I could solder on. Do you have any examples?
The filter is a good idea. When this is done, I will have to pot all these LEDS to make them weather proof. I have been looking into potting silicone and epoxies. The optically clear is about 3 times the price of the regular so called clear. The regular clear is not so cheep either. But might help in reducing the light output. Of course all this requires trial and error.
The high power resistor is currently the standard way LEDs are installed in automotive lighting. A 10W resistor is about $3.00 and is the same resistor I would use if I were to replace the incandescent bulb shown in post #1 with an equivalent LED replacement. It's just the price of retrofitting new technology into old technology.
