two-state LED driver controlled by a single GPIO
stagekraft
Joined Jan 18, 2022
28
Hey y'all, probably in the wrong place to ask this question, but here goes...
I'm working on a little project, using an AD DSP controller..
trying to use a single GPIO to control a two state led..
and of course, this should apply to any microcontroller using 3.3V GPIO
I found this circuit a while back in some online search, and did a screenshot of the schematic, and recently built up the circuit, and it almost works...
And of course, now I can't find the original article where I found the circuit. and only difference is 12V vs 24V powering the circuit.
Seems pretty straight forward, using a 3-lead/3-color LED (common cathode), power one side green, power the other side red, (and power to both yellow)...
The circuit consists of 2 pnp transistors driving the LED's, one biased on and the other off, and an npn transistor driven from a GPIO that makes the 2 pnp's change state, so should change from red to green..
But somehow there is enough leakage from the "on" transistor that the "off" state is yellow, while the "on" state makes green. ok, cool that it changes state, but the visual difference between green and yellow is sometimes hard to distinguish in bright light, would rather have a distinct green/red..
Any suggestions??
JohnR/stagekraft
boostbuck
Joined Oct 5, 2017
1,067
The turn-on path for Q3 is through D1 via R5 and R1. This is probably where the problem lies.
If your MCU can drive a LED directly from the IO pin, then this would be worth a try:
AnalogKid
Joined Aug 1, 2013
12,289
This approach has worked for me many times.
Depending on the GPIO pin capabilities, the center schematic might work for you without the inverter driver. Connect the D3 cathode directly to the GPIO pin.
The lower group of schematics is the same idea re-worked for a common-cathode LED.
ak
stagekraft
Joined Jan 18, 2022
28
I thank you all for your suggestions...
I have decided to go with crutschow's circuit, it is very close to my original circuit;
swap out Q3's PNP with an NPN, move a resistor, and add a diode...
fairly easy modification to my pcb (cutting one now on my CNC)..
And he was willing to share a tangible ltspice simulation, which I could easily replicate on my end.
but, then as they say, the proof is in the pudding, I will report back after I build the pcb
Thanks again
JohnR/stagekraft
stagekraft
Joined Jan 18, 2022
28
Ahhh, Silly old man...
I built up the pcb with crutschow's circuit, and it failed also, back to the drawing board...
AH-HA, I found I had made a layout mistake on my first pcb, which transferred onto the second pcb (which was a minor edit to the first)...
fixed the mistake on both boards, and now they both work correctly...
Must have been that #69 birthday I just had that turned my brain into pudding...:rolleyes:
JohnR/stagekraft
