I think you described it correctly as a loud speaker or horn. If you can remember or ever seen a pair later they came out with coaxial speakers and tri-speakers. the others taking up the mid and upper range while the main speaker took up some voice , music, bass, and some of the mid. Trying to work on a circuit in Diptrace you can understand. The reason I said they were acting like a OFF/ON switch is there was a toggle switch for power on the mindblower and what I call a (rheostat) on the treble, mid, bass knob that you could adjust to get each. the speakers never went loud until you hit the toggle switch (ON)? once you applied +12VDC then you got the amplifier. this was a little box that was screwed under your panel below the your steering wheel were you could reach it.Audioguru said:If the two transistors are only OFF/ON switches then their outputs would be rectangular waves and speech and music would sound like buzzers.
Having never seen or having one of these, it is sounding more like a cross over net work than an amplifier. Or a cross over network with an amplifier.The reason I said they were acting like a OFF/ON switch is there was a toggle switch for power on the mindblower and what I call a (rheostat) on the treble, mid, bass knob that you could adjust to get each. the speakers never went loud until you hit the toggle switch (ON)? once you applied +12VDC then you got the amplifier. this was a little box that was screwed under your panel below the your steering wheel were you could reach it.
Not trying to run you off, but really want to help. I know when I started in electronics it seemed like you got better help if you ask the right questions.This stuff is the hardest thing I've ever done.Thanks shortbus. I do like it here and I know me asking so many questions gets taxing. I will check it out. And I appreciate you pointing me towards Diptrace that was a great help.
But people like me and him that come into doing this later in life have to rely on places like this to learn. Or just not do it, which speaking for myself is not going to happen. You know this stuff, but forget what it was like when you didn't.I learned about electronics from magazines then learned the details in university. It was easy. You need a teacher who knows how to teach.
A off/on switch?Livescience said:A traditional mechanical switch either enables or disables the flow of electricity by physically connecting (or disconnecting) two ends of wire. In a transistor, a signal tells the device to either conduct or insulate, thereby enabling or disabling the flow of electricity.
They are both only transistors right? one place I read you can't put more current on collector than the input current "it would feed back through the wrong way on the transistor is my only guess" Or are these transistors two different types of the same item.google search said:Introduction: Simple Audio Amplifier Using Single Transistor. Audio Amplifier is a device which strengthen the weak signal. Usually in audio systems we use amplifiers to drive the speakers of high power rating .
Transistors can be used in linear or "saturated switch" applications. It just depends on how you build the rest of your circuit around them.Now we have the internet and it's a great tool "But" again when something don't make sense in your mind you can't raise your hand and get the answer your looking for. Like my trying to understand Transistors and their function. In one place you get one answer and the other you get another. For example a transistor is:
A off/on switch?
Then when you lookup audio amplification transistors you get this answer:
| Y | VNA calibration linked causality questions | Wireless & RF Design | 1 | |
| H | Questions on RFIC and Electromagnetic design | Homework Help | 1 | |
Current draw questions | General Electronics Chat | 37 | |
| T | Solder composition questions | General Electronics Chat | 9 | |
| C | basic questions about soldering. Beginner | Technical Repair | 47 |
