isolated mounts
96y
Joined May 8, 2019
38
wht do you use for eyelet bolt mounts that are isolated on plastic or other non conductive material...
for instance wanting to join 2 eyelet 3/8 ends together on a bolt mount on the side of a piece of wood but not have any current pass thru the wood..
96y
Joined May 8, 2019
38
i mis spoke. I meant how do people put a wire with a ring end on a bolt mount mounted on wood
or metal...to join 2 wires together..but keep the bolt from touching the wood or metal..
SamR
Joined Mar 19, 2019
5,472
Use insulated wire? If bonding the 2 wires shrink wrap the bond up to the insulation. Not sure what you are trying to do...
