Is this what I need..?
DickCappels
Joined Aug 21, 2008
10,662
If you are only doing a little bit of surface mount, you can tin the pads with solder (using extra flux makes this easier) then remove as much as you can using fluxed braid, leaving only a think film of solder on the pads. Components can be reflow soldred to the pads using a soldering iron, usually without the need for additional solder. Yes, flux during this procedure makes it go quicker and reduces the chances of creating bridges that short pads.
jpanhalt
Joined Jan 18, 2008
11,087
How small are the parts you need to solder? I generally stay with 805-size components and have never needed solder past. A few weeks ago, I did a 0.5 mm pin spacing for an FPC connector. Again, no solder paste, hand held iron, and fine (0.015) leaded solder.
The smudge at the bottom is some flux I failed to clean completely. I usually use the method described by Dick C., but only tin one pad and don't remove excess. Just a tiny drop of solder, then reflow with the iron.
If I have a whole lot of parts to do or when positioning is critical (as with the connector), I use a microdrop (<0.1 uL) of cyanoacrylic adhesive (CA, super glue) to fix the part(s) to the PCB, do not pre-tin, and solder away as usual. The nice thing about cheap CA is that it evaporates at solder temperature, so if a little gets on a pad, it doesn't interfere. Industry uses a similar adhesive in manufacturing some boards.
Several years ago, I tried solder paste. I found that the amount you put down is fairly critical, and the shelf-life is relatively short. I found no benefit to using it on a hobby scale. Clearly, if my project requires a lot of parts, then paste would be preferred.
pmd34
Joined Feb 22, 2014
529
I really recommend getting solder paste with some silver in it. It really helps the solder flow with small SMD components and pads.
I use ALPHA UP78 - 62Sn/2.0AG/36Pb (which i found from a chinese supplier) or ALPHA CL-78. Its always good to have a small syringe + needle of flux also, in case you have to reworks something, or if you have been a bit heavy handed with the paste and need to remove a solder bridge between some pins.
I use the solder paste in a small 25ml syringe with 26 or 28Ga dispensing needle which I use with an air driven dispensing unit. I keep the syringe and paste in the fridge and push some fine stiff (tungsten) wire I had laying around into the needle between uses to minimize wastage. Ive actually been using the same syringe of paste for many years now!
thedoc8
Joined Nov 28, 2012
162
The pins are .5 and already did 3 sides of the chip. I can't get to the back side of the chip so was going to use past. I ordered some and will be here tomorrow. Thanks for all the advice, not did a lot of sm.
jpanhalt
Joined Jan 18, 2008
11,087
Another approach to soldering to the back side, if it needs it, is to put a relatively large diameter PTH under the chip. and solder through that. With larger chips, I have put a puddle of solder on the center. Then heated from the rear until it settles in to place. Pins are done last.
Good luck with the solder paste. I wish it were sold in smaller, sealed packets like some repair packets of epoxy are sold.
Ya’akov
Joined Jan 27, 2019
10,278
Put the unused portion in the refrigerator, it will last much longer.
