Is this a good way to dim a 5-inch LCD for my Raspberry Pi?
hopalele74
Joined Dec 15, 2020
Hi. I'm trying to make a DPI display to work with my Raspberry Pi.
First, I searched around and found out that the 555 timer IC is a good way to control the brightness of the display. And since the background LEDs needs around 23V to function, I've included a step up converter.
It's for a LCD like this one: https://www.adafruit.com/product/1680
But then someone recommended me to use a LED controller instead. Is it a better choice? And if so, what IC would fit this project? That has both dimming and boosting function.
I'm a beginner and this is my first schematic design. So I'm open to any kind of feedback you might have.
Thank you.
ronsimpson
Joined Oct 7, 2019
4,897
but the backlight requires a constant-current mode boost converter that can go as high as 24V
I do not have a dats sheet for the display. We need to know how much current!
Replace U1 & Q1 with this. It will hold the LED current constant. You have 5V power on the Pi. The 555 will do the same dim thing it was doing.
