Is my brand new multimeter broken? =(
Discussion in 'Test & Measurement Forum' started by Joao scs, Jan 6, 2018.
  1. Joao scs
    Jan 2, 2018
    16
    Hi everyone!
    I just bought a multimeter and, in the continuity test, it shows 0.13 and beeps even without the cables! Is it broken?
  2. MrChips
    Oct 2, 2009
    18,533
    5,883
    Yes. Take it back to the store.
    johansenb and Joao scs like this.
  3. Joao scs
    Jan 2, 2018
    16
    Thanks!
  4. spinnaker
    Oct 29, 2009
    7,815
    3,672
    Did you try resetting it by removing the battery? Probably won't fix it but worth a try.
    Joao scs likes this.
  5. GopherT
    Nov 23, 2012
    7,983
    6,777
    No, your new meter is not neccessarily broken. This meter is trying to put a constant current across the PN junction and measure the voltage needed. If you have no path for the current. Also, it may be beeping because there are no leads in the unit (warning that the leads may be connected wrong (my Fluke beeps if I have no cables plugged in or plugged into the amp terminal when I switch to continuity).
    Connect it correctly and try again. Then get worried.
  6. bertus
    Administrator
    Apr 5, 2008
    19,523
    3,977
    Is the hold function off?
    Some meters will have the hold function on when you switch them on.
    Bertus
    Joao scs and spinnaker like this.
  7. Raymond Genovese
    Mar 5, 2016
    1,643
    989
    Check out this video at about 1:28, it might help
    It also helps to learn Spanish because I have no freaking idea what he is saying :)
  8. GopherT
    Nov 23, 2012
    7,983
    6,777
    Hard to learn Spanish from a Portuguese video (Brazil).
    Reloadron and Joao scs like this.
  9. Joao scs
    Jan 2, 2018
    16
    Thanks a lot! I will try everything that's been said and tell what happened! Really sorry to bother and really happy that you all helped me! =)
  10. Raymond Genovese
    Mar 5, 2016
    1,643
    989
    Can't make any excuse for that one - I capped out after El Camino Real
    GopherT and Joao scs like this.
  11. spinnaker
    Oct 29, 2009
    7,815
    3,672
    This guy either has really big hands or that is one tiny meter. ;)
  12. Raymond Genovese
    Mar 5, 2016
    1,643
    989
    You should see his buttons! (sorry couldn't resist that)
  13. Joao scs
    Jan 2, 2018
    16
    Thanks! Please, won't this violate the warranty? (Sorry for the bad english).
    I did it and didn't worked. So, time to be worried!
    Hold isn't on... =(
    Awesome video, but didn't helped (And I understood it, because I'm Brazilian!)
    Thanks everyone! Let's just hope they replace it for a new one! =)
    GopherT likes this.
  14. spinnaker
    Oct 29, 2009
    7,815
    3,672
    Removing the battery? Of course not. What do you think you will do when the battery is depleted? ;)
    Joao scs and GopherT like this.
  15. ian field
    Oct 27, 2012
    6,543
    1,197
    I think mine shows the infinity symbol just as with regular resistance ranges - but its not something you take much notice when there's readings to be read.
    GopherT likes this.
  16. spinnaker
    Oct 29, 2009
    7,815
    3,672
    Judging from this and your other insightful posts, it is obvious you are extremely knowledgeable in this subject matter. Perhaps you should help the TS out and expand on your claim? Maybe provide a detailed lists of tests that could be performed?
  17. GopherT
    Nov 23, 2012
    7,983
    6,777
    The post you quoted has vanished!
  18. spinnaker
    Oct 29, 2009
    7,815
    3,672
    I was hoping his other words of wisdom as well. But alas we shant be so fortunate. :p
    GopherT likes this.
