IR2117 High Side driver no output voltage
Nope002
Joined Feb 24, 2025
6
I'm trying to make a high side driver circuit for my mosfet but am unable to get any output from the driver
A possible error might be that the model is not working but I do not know how to test weather the model is imported correctly in ltspice.
1740390322675.pngI I am also making a breadboard circuit of the driver and am giving it 50KHz pulses, how do I test this circuit without directly giving the signal to MOSFETs?
Will just looking at HO and VS in a scope work?
I have attached the simulation and model files
bertus
Joined Apr 5, 2008
23,009
The IRF530 is not the right mosfet for you.
It is a 100 volts 16 amp mosfet.
You will need a mosfet that can handle the higher current and higher voltage.
Bertus
Nope002
Joined Feb 24, 2025
6
Bertus
Thank you bertus for pointing that out, I have gone ahead and changed the mosfet to one thats suitable for the current ratings. However there is no improvement with the driver output. It continues to remain at 0V
Nope002
Joined Feb 24, 2025
6
You have probably killed the charge pump diode. A 1N914 is only rated at 100V.
Thank you ian, I have gone ahead and picked a diode thats more suitable for this circuit. Are there any other errors I might be missing as this change did not rectify the problem with the driver output being 0V.
Alec_t
Joined Sep 17, 2013
15,156
Not true, see the data sheet.
Agreed, if the model conforms to the datasheet. If it doesn't, the model might be expecting logic High to be greater than Vdd/2. The TS could try increasing Vin to something greater then 10V (or else reducing Vdd to, say, 5V).
Edit: The above applies to the IRS21171, not the IRS2117. My bad.
0ri0n
Joined Jan 7, 2025
190
Read the datasheet. The IR2117 model, at least the one I have, is complying with the datasheet. It expects Vin > 0.63 x Vcc whereas the datasheet says min. 9.5V for Vcc = 15 V. At Vin = 9.45 V (63% of Vcc) the model stops working. For some reason the OP is using Vcc=20V, which would raise min. Vin to at least 12.7 V. Again, at 63% of Vcc (Vin = 12.6 V), the driver model stops working.
sghioto
Joined Dec 31, 2017
8,756
I stand corrected that the input is not TTL compatible.
My interpretation is a minimum input of 9.5 volts regardless of Vcc and a max input equal to Vcc +.3 volt.
