Hi,thank you for your comentIf the range is 3.5m when the battery is brand new then the range might be 1m or less when the battery has run down a little.
You did not say what is the value of the series base current-limiting resistor for the PNP, and what is the battery voltage when it is working.
Thank you for your commentHave you checked the frequency of the oscillator? I would expect better range than that if you are pumping more than 100mA into the LED.
Bob
Beautiful explanation.I am very thankful!You connected your current meter to the output of the TLC555 and measured 17mA into the dead short of the meter. You should never short an output like that.
The extremely low value of your series base resistor of only 3 ohms is useless. Instead allow about (3V - 0.7V/2)= 1.15V across the resistor then the typical base current will be 8mA but yours is higher than typical so it will be about 14mA.
A little transistor is saturated when its Vce is less than 0.6V, typically 0.2V. The datasheet for a 2N4403 PNP shows Vce of 0.15 typical or 0.4V max at IC of 150mA and Ib at 15mA.
Your poor range might be because your IR pulses do not meet the requirement of burst length and gap time between bursts since an IR detector IC turns down its sensitivity when they are wrong due to it being caused by interference from a compact fluorescent light working at 38kHz.
Thank you!Two additions might increase range 6X; on TX add a short focus lens about 3 cm dia. to bring 20 deg. down to 2 deg. & add a cone concentrator for Rx, maybe 2 cm entrance, 3mm exit, & 3 cm long. I use Al tape with thin cardboard backing.
Thank you!!!Your European BC328 is almost the same as my American 2N4403 except its pins are the reverse.
Instead of shorting a circuit with a current meter, put in a series resistor, measure the voltage across it then use Ohm's Law to calculate the current.
Do you understand the importance and spec's of using the IR pulses correct burst length and gap time between bursts?
I agree,but it us quiet impossible to achive a frequency of 30 kHZ even with the variable resistors.I was able to do that,but after 5 min frequency goes up or down a bit.The TSOPs are very selective. A frequency of 31KHz would likely reduce the range.
Bob
Unfortunately i am not familiar with that oscillator.Is there a big difference between these two?I have only used them with a microcontroller with a crystal, so the frequency would be accurate to within a few Hz.
Perhaps you need a crystal oscillator in place of the 555 to get the vest range and reliability.
Bob
So where i can buy that lens?To show range improvement with a lens I setup on bread board a C555 driving a LTE 2871 IR LED
via 2N3904 as emitter follower driving a 2N3904 as a switch. Output about 80 mA @ 30 % duty cycle, 30 kHz. Receiver is OPL561 driving a red LED. Range about 50 cm with cone on Rx no lens on Tx. With lens on Tx range is 6m. Adjustment is touchy.
Thank you!Try small folding pocket magnifier, 2 to 3 X magnification. Mine from ACE hardware, or office supply & many found on line.
OMG thank you!!!hi optus,
Do these LTS sims represent the results you are expecting.?
General plots from 3V and 2V battery.
Expanded plots, nominal 600Hz and 40kHz
Look them over.
E
