Thank you...good explanationhi,
You would get only 0.65V because you do not have a series resistor, you are shorting pin 3 to 0v via the transistor BE junction [ Not recommended]
E
E
Thank you.I respect everything that you wrote.With an output current of only 2.2mA then the TLC555 does not need an output resistor to "limit" the current because it is already limiting the current. The transistor will saturate only if you limit its output current to 2.2mA x 10= 22mA but the very low value of the collector resistor is causing the collector voltage to be far from saturation. You do not have enough base current, that is why I said do use two transistors to increase the current.
The output current of a TLC555 can go low with almost 10 times the current of it going high which is also a bonus if you use two transistors. Its maximum allowed output low current is 150mA so use a series resistor to limit its output current to about 5mA. Then the base of the PNP transistor gets 5mA and its output will be saturated at 50mA. Limit the current to 20mA for the base of the NPN transistor so its output can saturate at 200mA into the IR LED.
Yes,i know.Everything you said its true.I tried just to observe if anything will hapen.But since it didnt i was wrong in some point.Guesing that is because there is a short circuit when there is no base resistor and when it ocurs there is 0V drop(in this case 0.65 V although i dont know where it come from??) Tomorrow i will start to use 2 transistor so i hope good things will emergeWon't the range be very short if the current in the IR LED is only 22mA? Won't the range be much longer if the LED gets 220mA?
Will the circuit still be useful when the battery voltage has dropped to only 2V?
If the IR LED will survive 220mA then your circuit needs two transistors.
yes
yeshi,
The images were posted so that you can see the non linear element in the right side plot
Should i treat IR led as a linear or a non linear element since there is a diference between these constatations???
If you decide on the current you want thru the diode and the duration of the current pulse, use those images to show the plot for your values.
Please confirm and post the design pulse current and its duration.
E
If Tp/T=50%(0.5) then with let's say tp=0.000021s(0.02ms) curent is aprox.300 mA?hi,
A Vfwd = 1.25V at a current of ~ 10^2 = 100mA, no other calcs are required . 1st image
Check this 2nd image, what does it tell you.?
E
so,by the graph if i want let say curent of 300 mA,max. puls duration must be 0.2 ms when d.c. is 50%???hi,
The actual current thru the LED and its ON time is set by the designer.
The graph shows only the permissible maximum current for those On durations, which the designer has to ensure those limits are not exceeded.
Looking at 100mA, you can see that the On time can be virtually continuous, it will not damage the LED.
E
| Thread starter | Similar threads | Forum | Replies | Date |
| L | Bi-directional current limiting circuit? | Power Electronics | 17 | |
| C | Schmitt trigger debounce circuit problem(s) | Digital Design | 11 | |
| F | Basic Amp Circuit Question | Homework Help | 4 | |
Capacitor discharge circuit in modern multimeter | General Electronics Chat | 31 | |
| L | Did you ever make a circuit and gift to your loved one? | Off-Topic | 15 |
