inverting RGB signals, how to?
NOISEBOB
Joined Jul 7, 2019
48
hello
how would i go about inverting a RGB signal? inverting in the way that red, green and blue becomes cyan, magenta and yellow.
as far as i understand the -300mV to 0V part of the signal is the sync and should stay untouched and the 0V to 700mV part is the actual video information, and could be inverted.
question is, how do you invert only parts of a signal?
by using an opamp, i suppose i could invert it so it goes from -700mV to 300mV, then feed it +1V and end up having the whole signal inverted -300mV to 700mV, but then the sync part is 'lost'.. right?
34,925
hello
Inverting red does not give you cyan.
Inverting 0-100% red will give you 100-0% red.
To generate cyan you need to remove red and mix green and blue.
34,925
Yes.
If you have 100% red, 0% green, and 0% blue, and you invert all,
0% red, 100% green, and 100% blue will give you cyan.
