Inverting amplifier for signal biased at 2.5V.
Bod
Joined Sep 18, 2016
317
I don't really want to bring attention to that post of mine, because it's a bit of an embarrassing one on my part, but a good learning experience nonetheless.
In that post, I basically asked for a circuit that would take an audio signal and centre it at 2.5V (clamped between 0V and 5V). Although I wanted to use it for LED strips, I didn't actually have any led strips to control.
Months later I do! I came back to the post looking for a circuit knowing there's lots there. I ended up settling on BobTPH's circuit because that was exactly what I wanted - and it worked (honestly not sure how it didn't work when I tried it back then)
However, the output of this circuit, and others I have tried, all seem to be inverted, like below (what's the reason for this?):
Anyway, for the sake of continuity, I want the input to be the same as the output, not flipped upside down. Normally I could use an inverting amplifier but I believe because of the way the audio signal is (entered @ 2.5V), a normal inverting amplifier will not work:
(blue line is output of inverting amp)
Is there a simple way to invert the output signal?
(I just though - about three seconds before posting - maybe I can put the inverting amp on the very input, so the audio going into the first LT1366 is inverted, meaning the output is the right way up)
TeeKay6
Joined Apr 20, 2019
573
Use a non-inv amp configuration:
38,781
The output you show cannot be from the circuit you show, as it has two inverters in series so the output would be in phase tihe the input.
Also the DC offset from the first stage would cause the second stage to be clamped at 0V.
Here's the simulation with the output op amp (+) input connected the to the input amps offset voltage.
Wolframore
Joined Jan 21, 2019
2,619
I believe the dual inverting circuit at the end was TS’s solution which he proposed before posting.
i would go with a non-inverting circuit which has the advantage of higher input impedance.
Bod
Joined Sep 18, 2016
317
It works perfectly, thank you!
The top output I showed (the sine wave) was not from my circuit. It was an just an image from online to represent my problem (didn't have access to LTSpice at the time).
This also work very well. Thanks!
