LM7171 Non-Inverting Amplifier Output Weak & Distorted After 32 MHz LPF
flyingphoenix
Joined Jun 2, 2025
10
Hi guys, I need an insight, please help me.
I'm building a non-inverting amplifier, where the goal is to amplify a 32 MHz low-passed-input signal. 1kΩ fixed resistor, and a variable resistor with max of 10kΩ.
The original signal is a 100 ps pulse at 500 kHz, connected to a photodiode (PDA10A2). This is then passed through a commercially available 32 MHz low-pass filter (Mini-Circuits – 32 MHz, 50 Ω | SLP-30+), which filters out high frequencies. The output from this filter is connected via a probe to the input of my amplifier circuit.
However, when I observe the output on the oscilloscope, the output signal (purple) differs from the filtered input signal (yellow):
  1. The amplitude drops significantly. I expected it to increase due to amplification. Even when the potentiometer is turned to maximum, the output remains low. If the potentiometer is at a value none other than the maximum, no signal appears at all. At this point i dont even know if the pueple waveform is indeed an output or just noise.
  2. The waveform shape changes slightly. I was expecting a similar shape to the input, just amplified.
I know that the amplification is limited by the power rails (±5 V), but even when I increased the supply to ±10 V or ±15 V, the output signal still looked the same.
I also made sure the gain is above 2, as stated in the LM7171 datasheet for stability in non-inverting configurations.
I’ve added decoupling capacitors, but they had no noticeable effect.
Please, anyone have any idea? Thanks!
ronsimpson
Joined Oct 7, 2019
4,810
You need a capacitor from +5V to -5V at the op-amp pins. You probably should have caps from +5V to gnd and gnd to -5V. Keep the leads short. 0.01uF or 0.1uf or almost anything is better than nothing.
0ri0n
Joined Jan 7, 2025
190
The op amp has no feedback and is basically working as a comparator because the 10k trimmer VR1 is not connected.
flyingphoenix
Joined Jun 2, 2025
10
Hey sorry that was drawing error. I did connect one of the outer terminal of potentiometer to the input, and the wiper to the output, creating a feedback
