inverter chani 1000watt
boz1shot
Joined Jul 20, 2024
7
i have being working on this invert 500watt
i fine out that there is no 12v on tl494 number 8 pin and the input mosft gate are all 12v
if are add mosft to it, it we blow offm what will be the problem
LowQCab
Joined Nov 6, 2012
5,102
The TL-494 can not supply enough FET-Gate-Drive-Current for a very High-Power-MOSFET.
2 separate, dedicated, Gate-Driver-Chips will be required to get good Switching-Performance and
to avoid burning-up your expensive High-Power-FETs.
boz1shot
Joined Jul 20, 2024
7
but th
but the dc side of the input mosft gate side is giving 12v when murs with meter, most that be the cost of transisors
LowQCab
Joined Nov 6, 2012
5,102
The Gate of a MOSFET acts exactly like a Capacitor.
This Capacitor will have to be Charged-Up, and then Discharged, at an extremely high Frequency.
This may require a serious amount of Current, not just "Voltage".
Hopefully, your design, ( which we haven't seen yet ), does not use excessively high Frequencies.
boz1shot
Joined Jul 20, 2024
7
This is the inverter pic
This is the pic of the inverter, all the gate , source and the emiti are all given out 12v which I have not com across this kind of issue before we
LowQCab
Joined Nov 6, 2012
5,102
You didn't say that You were trying to repair a commercially produced inverter.
That's a whole different bucket of Worms.
Good Luck.
