Input DC Voltage into Full-Bridge Diode Rectifier
koshi
Joined Sep 25, 2014
27
Hi guys!
I have read similar threads in this forum with regards to this topic. But their questions are mainly focusing on the probability of replacing the AC source with a DC source. As for me, I am curious to know what will be the output voltage if I input a DC voltage of say 230V into the diode bridge. I did a simple simulation of this and I got an output of 230-1.4= 228.6V and the result seems about right (I attached the result). Practically this should be true as well right?
I am trying to feed a DC input voltage into the input of an AC laptop adaptor instead of using an AC source.
Usually a 230VAC source will be used an input for the AC adaptor, but if I use DC instead, should I be using 230VDC as an input to the AC adaptor or do I have to treat the 230VAC source as an rms value and use 325VDC (230*1.414) instead?
Any inputs are appreciated.
Thanks.
dl324
Joined Mar 30, 2015
18,328
The reason I am asking this is that I am interested in feeding an DC source directly to the AC adaptor of the laptop instead of an AC source. As for the case of the AC adaptor, I will usually need an AC source of say 230VAC as input. But if I am interested in replacing the AC source with an DC source instead, what will be the DC input voltage required?
Not sure what you're asking.
Are you intending to feed DC into the input of an AC adapter?
radiohead
Joined May 28, 2009
514
With DC voltages, the full-wave rectifier bridge (assuming the bridge is rated for the input voltage), will only serve as reverse-polarity protection. Expect a voltage drop of around 1.4 volts DC or so because there will always be two forward-biased diodes.
The DC output of the bridge is connected to the (polarized) device you want to run... + to device positive, - to device negative. The input voltage should be at or very near the device operating voltage.
The input voltage is applied to the full-wave bridge ~ terminals (intending for AC voltage)... Input polarity to the full-wave bridge is irrelevant, the output polarity will always be correct.
Reloadron
Joined Jan 15, 2015
7,889
Do I have to consider the peak DC voltage as compared to the rms value of the AC source or is it a 1:1 ratio?
1) So if the AC laptop adaptor requires an AC input of say 230VAC, the DC equivalent will be approx 325VDC?
2) Or can I just feed an DC source of 230VDC to replace the 230VAC directly?
When we look at DC Epeak = Eavg = Erms
The DC equivlent of 230 VAC RMS would be 230 VDC and the DC equivlent of 325.2 AC Peak would be 230 VDC and the DC equivlent of 650.4 VAC Peak to Peak would be 230 VDC.
The RMS value of a Sine Wave (we are talking about sine waves) is .707 * Epeak. Epeak being equal to 1/2 of E pk to pk.
Make sense?
Ron.
koshi
Joined Sep 25, 2014
27
Make sense?
Ron.
Shouldn't it be the reverse way? 230VAC will be 325VDC? Since 230VAC is in rms value and VDC = VRMS * 1.414
koshi
Joined Sep 25, 2014
27
Thanks for the input. But in this case, should I be feeding 230VDC or 325VDC? If I consider the initial AC source to be 230VAC.
dl324
Joined Mar 30, 2015
18,328
Already answered by @Reloadron; 230VDC. And that's assuming the adapter is a transformerless switching regulator.
But, 230VDC and 230VAC are potentially lethal voltages. Do you know what you're contemplating?
Reloadron
Joined Jan 15, 2015
7,889
That gets you Epeak, Vrms * 1.414 = Epeak.
Generally when not specified we assume Vrms. For example the US standard is 120 VAC or 240 VAC 60Hz and this is RMS while not called out. Back to what I mentioned with DC, Epeak = Eaverage = Erms. The RMS value of a sine wave is the DC equivlent.
Ron
AnalogKid
Joined Aug 1, 2013
12,130
Yes, but -
That is all true for equivalent energy, but not necessarily for what the power supply controller wants to see as a viable input. If it is not of the universal input type, then it might require a minimum input peak voltage that is equivalent to an input sinewave of 240 Vac minus a design margin of maybe 20%, or 271 Vdc. More and more industrial power supplies are rated for both AC and DC inputs, but older power-factor corrected front ends still want to see a sine wave input and might shut down without one.
ak
Reloadron
Joined Jan 15, 2015
7,889
Yes, but -
ak
And that would be true and need considered, so it all depends on what you have.
Ron
AnalogKid
Joined Aug 1, 2013
12,130
More to the point WHY do you want to replace AC for DC???
Don't know about the TS, but military aircraft can have high voltage AC and/or DC power buses. A truly universal input supply handles 85-265 Vac at 45-440 Hz *and* 270 Vdc +/- 20% (working from memory).
ak
radiohead
Joined May 28, 2009
514
Feeding 320 VDC into the 230 VAC input of a computer power brick is not a good idea. I am fairly confident it will not work. Wear safety glasses and stand back when you flip the switch. I am curious to see the results... can you post a video on youtube?
