Is there a limit to boost voltage with LM2577S-ADJ using 5v input
gray-b
Joined Aug 4, 2025
89
Trying with 5v input from USB into a pretty standard circuit using LM2577S-ADJ to get 60v
After changing a lot of components, all I can get as output is 54.4v
Is this the max voltage output you can get out with such a low input voltage.
I have tried input caps 100uf and 220uf, inductor 100uH and 330uH, output caps 1000uF with 1uF poly.
Only using 1 half of MBRF10100CT
• 100 V, 10 A dual Schottky (5 A per leg)
• Trench MOS Schottky technology
• Vf ≈ 0.75 V @ 5 A, lower at light current
• Very low switching loss
Has made no difference.
Any ideas or suggestions.
Or should I try to get the R1 and R2 ratio more accurate (in my case R1=100k + 1k and R2 = 2k2). That is to reduce R2 to 2k11 ?
38,938
You are probably being limited by the maximum duty-cycle the chip can generate.
Goggle AI suggest the maximum step-up ratio for typical circuits is about 10:1 (i.e. 50V for a 5V input).
So for higher voltages you could go to a flyback converter configuration with a transformer, or use two boost converters in series.
